Page 5 of 6 FirstFirst 123456 LastLast
Results 101 to 125 of 134
  1. #101
    Aug 2019
    Stoughton, WI
    Went really well. All told, spent about 1.5 hours riding/data logging and 1.5 hours on the computer tweaking the map. The bike feels much crisper regarding throttle response and pulls much harder on top. Jamie said fuel tables were off by as much as 16%, with many areas being too rich and some areas too lean. When all was said/done, he got the fuel tables within 3% of what he thought was ideal. He left ignition points alone and made minimal timing changes. He "thinks" if the bike ran well on 87 octane before the flash that it will run fine after the flash. I'll likely ween it down to mid grade (89 octane) and see how it goes. The end result is very satisfying.
    2022 RT Sea To Sky
  2. #102
    Sep 2014
    USA
    I haven't done it yet but how did you data log?
  3. #103
    Aug 2019
    Stoughton, WI
    I did about 75 minutes worth in total, of a wide multitude of riding styles. It will log for approx 15 minutes and restart another log. No need to stop/start your data logs. With the bike running, go to your 4 square channel screen and press the round circle button. It will glow green and a logging icon will appear. Stop log with power still going to the PV3.
    2022 RT Sea To Sky
  4. #104
    Sep 2014
    USA
    I will have to send my logs into dyno jet.
  5. #105
    Active Member SmoovOpRatoR's Avatar
    Nov 2015
    West Coast, Canada
    Fuel table off by 16% seems kind of crazy, is there any particular reason that Dynojet would leave it like that? I may have to do some logging too.
  6. #106
    Aug 2019
    Stoughton, WI
    Only can tell you what he told me. He did say that the DJ map was a really nice starting base. May have been a very small spike. I never asked him where, but it seems a lot of maps are rich in the cruise area. I did 20 minutes worth of logging on the freeway at steady 60, 70 and 80 mph speeds.
    2022 RT Sea To Sky
  7. #107
    Active Member T.P.'s Avatar
    Oct 2016
    APPLE VALLEY, MN
    Perfect pic.https://www.instagram.com/p/B_2xqemBolC/
    Thanks Jeff (TROOP) For doing the leg work. I just about got up early yesterday to ride over to Little Chute To see your process at Fuelmoto.
    And what was the cost of you time there ?
    T.P.
  8. #108
    Aug 2019
    Stoughton, WI
    Over the years, I'm a 5x repeat customer with various bikes, so I think he cut me a nice break. That said, if you buy from them, they'll customize all your future mapping for no charge with supplied data logging. Give them a call.
    2022 RT Sea To Sky
  9. #109
    May 2020
    Virginia
    @Troop
    Would you be able to share your original STK file with me? I am looking to get the PV3 for mine and I wanted to see what calibrations/tables are avalible inside the map using the PV3. It seems you cant look around without the STK file.
    Thanks
    Later
    Dominick
  10. #110
    Aug 2019
    Stoughton, WI
    When you buy/connect/power on your PV3, it will get you your stk file. At that point, it will tell you what djk files are available. stk file not obtainable without a PV3.
    2022 RT Sea To Sky
  11. #111
    Oct 2016
    APPLE VALLEY, MN
    I agree with TROOP on the above, My STK and my DJT are not the same as TROOP'S. Years and Models have different Stock and DJ tunes.
    T.P.
  12. #112
    Active Member ssmcclub's Avatar
    Apr 2013
    massapequa ny 11758
    is this the plug to hook up the dynojet pv3 2019 f3s
    richie spyder
  13. #113
    Aug 2019
    Stoughton, WI
    Quote Originally Posted by ssmcclub View Post
    Yup it is
    2022 RT Sea To Sky
  14. #114
    Apr 2013
    massapequa ny 11758
    Is this the plug on my bike that the dynojet pv3 hook up toplug 4 good.jpg do they all look like this for the can am spyders f3s
    richie spyder
  15. #115
    Apr 2013
    massapequa ny 11758
    ok thank you
    richie spyder
  16. #116
    Invalid Emails
    Feb 2020
    Splendora TX
    Hi, so if I may, will the DynoJet or for that sake any of power updates/ flashes change the emission readings to where it won’t pass the inspection emissions testing... I live in the Houston area with the dreaded test!!!
  17. #117
    Oct 2016
    APPLE VALLEY, MN
    Quote Originally Posted by jsflash View Post
    I think you better call DYNOJET, Good ?
    T.P.
  18. #118
    Aug 2019
    Stoughton, WI
    I'm guessing your exhaust, or lack of a catalytic converter, would affect that more. But, yeah, call DJ for that.
    2022 RT Sea To Sky
  19. #119
    Invalid Emails
    Feb 2020
    Splendora TX
    Will do!!! still have the cat. but the exhaust is more like a small 8-10 inch cherry bomb with a tip, barely sticks out from under the cycle, I was told the lady’s had a Harley and she liked the popping sound... and it does pop, especially when you down shift coming to a stop, not to loud just a deep throaty pop... I really kinda like it myself
  20. #120
    Aug 2019
    Stoughton, WI
    Your CC will clean emissions more than the muffler..
    2022 RT Sea To Sky
  21. #121
    May 2020
    Virginia
    @Troop
    Yes I am aware of dynojets process, I am just looking to understand what tables are available, specifically any tables related to fuel pump duty cycle or similar. like the attached. Fuel Pump Duty.jpg
  22. #122
    Apr 2013
    massapequa ny 11758
    should I buy the pv3 from dynojet or fuelmoto ?
    richie spyder
  23. #123
    Aug 2019
    Stoughton, WI
    I'd go Fuel Moto. You'll get everything DJ has to offer + any maps that Fuel Moto has in their data base.
    2022 RT Sea To Sky
  24. #124
    Mar 2014
    Troop
    What bike do you have, I have the dynojet and am not impressed. So I am getting the monsterfuel tune stage 2 and tuner. But here is the dilemma I have a 2018 F3s and monster told me there is a ECU New version update, that fixes a rich problem it can get. So I update my ECU and actually there where 3 update's for it in total. Know my dynojet will not recognizes the new version and dynojet has been giving me **** about it . I will call back Monday to see what they can do. My point is that even though we can down load the stock tune and take it in for updates the dynojet will not recognize it and will not work. Just giving some info to everyone
  25. #125
    Aug 2019
    Stoughton, WI
    Hmmm... Interesting. I have a 2019 F3S and it's running fantastic after the map tweak. Did you see/follow this link?
    https://university.fuelmotousa.com/a...-flash-update/
    2022 RT Sea To Sky
