Results 1 to 23 of 23
    May 2016
    Noblesville, Indiana
    Default I am ready for touring...
    Who said these trykes are not for touring??
    I'm now all set to cruise the country.
    Adequate storage.
    Home made shield.
    Atlas throttle lock.
    Alaska Leather sheepskin seat pad.
    Floor boards.
    65mm socket stored under the hood.
    Bluetooth connectivity from phone to helmet for GPS, music and everything else.
    I wonder if I'm missing anything???
    Ryde on,
    RykerUSA
    Jan 2009
    austria
    I plan the same here in the alps - but sometimes 2up !! it seems you have everything you need - maybe a bottle-holder and a largeer tank-bag ??
    Active Member Raprider's Avatar
    Oct 2017
    Central NJ
    +1 on Chris' suggestion for bottle holder...check out Drinks2Go.com
    Raprider (Rich)
    2016 Can-Am Spyder ST-S SE5 Steel Black Metallic (Blackbird)
    BRP Audio, Heated Grips, Fog Lights, Passenger Backrest, Givi Saddlebags/Top Case
    BajaRon Swaybar, TricLed Wide-Vu Mirrors, Lamonster Ram mount and X-grip, Sena 20S Evo Dual
    TricLed Sequential Front SpyderFenderz, Dual Color Run/Brake/Turn LEDs, Brake Flasher
    Kumho Ecsta AST installed on rear 4/2021
    1996 Yamaha Virago 750 (Vera) - still riding
    1987 Honda Shadow 500 (Shady) - sold
    1982 Honda Rebel 250 (Little Reb) - sold
    Jan 2009
    austria
    Quote Originally Posted by Raprider View Post
    I took the cheapest one for a bicycle - less than 10 dollars - was easy to fix with 2 screws in the plastic ..
    (looking for a "black-bottle-Sponsor )
    Nov 2018
    N.E. Ohio
    Quote Originally Posted by RykerUSA View Post
    Adequate storage.
    Home made shield.
    Floor boards.
    Ryde on,
    RykerUSA
    Hey RykerUSA, Where did you get your soft bag set up? cueman
    May 2016
    Here you go. EBay.
    Active Member bcraig's Avatar
    Grove City, OH USA
    Quote Originally Posted by chris56 View Post
    I've been looking about doing the same thing. Just curious why you mounted on right side. Unless you have a throttle lock you won't be able to use the bottle of (fill in the blank) unless you are stopped. If you mounted on the left side you could take a drink while still moving. Am I missing something about the left side?
    Nov 2018
    N.E. Ohio
    Yes, the parking brake.
    Very Active Member Markubis's Avatar
    Jan 2018
    NH
    Quote Originally Posted by cueman View Post
    Ogio also makes a nice universal saddlebag set-up but they are more expensive at around $160.
    https://www.amazon.com/OGIO-110093-3.../dp/B0035JCO7K
    I am leaning towards the Viking saddlebags myself though at only $90
    https://www.vikingbags.com/axe-sport...saddlebags.htm
    Default That you are....
    Well done Now off you go and you will have to get back to us on the results of all the hard work in getting yourself set up. We have seen several mentioning long distance rydes and what they need to make it better but you do have a nice set up....
    Gene and Ilana De Laney
    Mt. Helix, California
    ​2012 RS sm5
    Nov 2018
    Virginia
    Adequate storage.
    Home made shield.
    Floor boards.
    Ryde on,
    RykerUSA
    So what else do you need. My first 10 years consisted of a bag strapped to the rear seat. I gotten soft over the next 35 years of riding but I could still do it if I had to.
    The point is: just go out and do it. Tune up as you go along.
    2018 Can Am Spyder F3L, 1995 BMW R1100R, 1988 Suzuki GS250, 2019 Ryker 600 (Wife's)
    May 2009
    Connecticut
    What windshield? It appears to attach to the 4 mounting stock holes? Look bigger than my MRA universal windshield. With most smaller windshields you get a LOT of side winds because their not wide enough.
    Sea Doo GTI-SE 90 Jet Ski!!
    Active Member MidlifeRyker's Avatar
    Mar 2019
    CO
    Awesome work!!
    Can you show your A-frame (or whatever frame) you made for your saddlebags to not touch the wheel/fender? I'm receiving the same ones this week.
    Looking awesome!
    2019 900 ACE , Black
    May 2016
    To support the saddle bags, I went to my local Wally World and purchased 2 metal yard sticks. I simply slid the yardsticks through the Max mount and them bent them down on each side and it works just fine.
    Mar 2019
    Ruidoso Downs, New Mexico
    Quote Originally Posted by Sarge707 View Post
    Looks like a CalSci (which is what I have, much better than the stock/optional).
    Mar 2019
    RykerUSA, I see they come with a variety of straps. How did you fit them under your 'top bag'? I have a Chinese Givi box, wonder if the straps would fit under it. Do they go over the top of the Max Mount or through it like the yard sticks? I'm through with long distance touring but want to be able to take it on a week long trip or two.
    May 2016
    My saddlebags are just laying over Max Mount. My Top bag is strapped to Max Mount over the saddle bag center support band. I cut off all of the straps from the saddle bags as I do not use them. I have one bungee cord that straps across the front of 1 saddle bag underneath the Max Mount and attaches to the other saddle bag holding them together in position. I have not taken them out on the interstate yet but I'm pretty confident that this will work.
    Yardsticks go through the Max Mount and then you just bend them down to the form/position of the Max Mount so that they are hanging down on each side supporting the bags away from the wheel and clearing the swing arm.
    May the force be with you.
    Mar 2019
    FL
    Yardsticks go through the Max Mount and then you just bend them down to the form/position of the Max Mouth so that they are hanging down on each side supporting the bags away from the wheel and clearing the swing arm.
    By "yardstick" do you mean a regular metal 36 inch ruler?
    Central NJ
    Picture please
    Mar 2019
    CO
    LOL. This is awesome! And a lot easier than what I was envisioning as a weekend project. Thanks!
    May 2016
    Yep. 36 inch metal ruler.
    May 2019
    Washington
    what kinda of wind sheild is that?
    May 2016
    I cannot remember the brand name but I had it laying around the garage. It came off of an fjr 1300 Yamaha sport touring bike. I trimmed it down to size using my trusty dremmel. I have skills.
