Motorbike Professor
What kind of noise? If it is a knocking or clunking sound, you probably are not only right, but on the verge of major damage. There have been some reports of worn out shock bushings. Other front end problems have been reported, too. If the A-frames havend been properly lubed, those bushings could be gone. Sounds like time for either the dealer or you to tear into it to see what is going on, before the tires wear out or serious problems arise.
-Scotty
The noise I am hearing is a creeking noise like a door opening. The machine only has 400 miles on it.
Had the same problem and noise. Dealer ended up replaceing the shock.
Noisy front end
I've had the same problem. It is a creaking noise when you rock the bike side to side. My dealer says he has taken a look at it and creased all the fittings but it still does it. Maybe it's the shock but he seems to think it may be the spring itself. Any suggestiolns?
Juice
Happy owner of 2014 White RTS - SE6
MOgang Member
I checked mine last night and it to sqeaks when you rock it back and forth.. Its going to the shop for a oil change on Friday and I am going to mention that to them... what the heck!! I didn't look at it that hard but it appears that it is somewhere near the upper mounting bracket/hardware where the shocks bolt on..
Joe
I fixed mine by disconnecting the swaybar at each end and greasing the joint that it connects to on the bottom of the swingarm.
MOgang Member
This is a PERFECT fix.. Lets call these two little plastic pieces a DOG BONE because thats what they look like. How can you put PLASTIC on a bushing with NO GREASE and expect it no to make noise...
Teaburd: I am sure this is what you are hearing,, this is a 15 minute fix that will stop the noise.. I just did mine and what a difference... Give it a shot and if you need more info let us know but again, this is the problem.
Joe
You could probably spray some wd40 in there without disassembling anything.
The problem I had (and I believe the original poster had too) was not a simple 'creeking' or 'squeaking' - it is a very pronounced 'CLICK' - with a bit of a plastic sound to it. It's the sway bar coming up too far and hitting the a-frame or the trunk and causing the trunk to flex and make a plastic sound because something is loose -
Check all the bolts that pertain to the sway bar - I tightened all of them and it the problem is gone. I believe it was some of the ones right near the trunk - not the ones on the 'dog bones'.
Hey, does it sound like this....about 20 seconds into the video.
http://www.popularmechanics.com/blog...s/4212570.html
MOgang Member
No mine didn't anyway, not sure how the original post was but I just beleive that is the shocks going in and out on that clip.. Mine was a sqeaking noise...
I should have done that while I was underneath the spyder, I will get to that tomorrow just to make sure they are all tight.. Thanks for the heads up.
Joe
