Results 1 to 16 of 16
    Mar 2017
    Default F3 T, does one need to remove a bag in order to pull the rear wheel?
    EOM Kenda lasted less than 13K which sucks and I ain't puttin on another one. I watched a you tube video about pulling the rear wheel, but that was an F3 (not T). Curious if one needs to pull the OEM saddlebag in order to pull the axle and release the rear wheel. I would try it, but I'm on the road. TIA
    Jul 2010
    Las Vegas, NV
    No. Axle slides out to the left. Raise rear enough that the wheel can roll out.
    Joe Meyer
    Very Active Member NautiBrit's Avatar
    Jun 2008
    Buckeye, AZ
    It's not necessary to remove a bag. Remove the rear brake, jack up the Spyder, the wheel will drop to allow access to the wheel bolts, lower the bike and remove the axle.
    George
    2017 BMW R1200R
    Mar 2017
    Thanks! Much appreciated. How about getting the tire mounted on the rim? Any tire shop??
    PS. the rear fender center piece can be removed too.
    SpyderLovers Sponsor
    Jun 2010
    Las Vegas
    If you have a motorcycle tire shop near you they can likely mount and balance it for you. Motorcycle dealers will sometimes do it as well. Let your fingers do the walking through the yellow pages and call first!
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Mar 2017
    Will call the Can Am power sports here in SC to see what they say. Most will not mount a tire they did not sell to you though as has been my experience with my Goldwings.
    Jul 2011
    Mitchell, Ontario, Canada
    From my experience. Almost all car tire shops can mount the new rear tire for you. Almost none can balance it. I used beads the last time. That is if they are willing to do it. Motorcycle shops can mount the new rear tire and likely balance it too. Would be highly likely to do the whole job for you.
    Nov 2012
    North Las Vegas, NV
    No need to remove a saddlebag, if you get the tire mounted and they can’t balance it, get some stick on weights and use the axle between 2 jack stands to find the heavy spot.
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    Mar 2017
    Will be getting on the phone to Power Sports in Greenville Tuesday. It's pay them or spend $100 on a jack.... but, with Harbor freight's generous return policy, I might just "borrow" a jack. I don't have one that will lift her high enough. THX much. It has been my experience that the bike shop won't mount if you did not buy from them.
    One can insert the beads through the valve stem. Used to do that on my wing tires.
    I have done that as well. Good suggestion!
    Mar 2017
    As I said, the bike shop will NOT put anything on the F3-T but the kenda. Won't mount a khumo or anything else. So, I'm on my own here.
    Mar 2017
    I found an independent shop here in Taylors SC to get the Kumho mounted.
    >CLICK ME<
    Mar 2017
    With a little help from my aircraft mechanic daughter (USAF Charleston) got the wheel off. More photos to follow.
    I hope that's the new tire waiting to go on?!
    Lookin good tho! Shouldn't be too long now, but we are all waiting to see what you think once it's on & you can go do some ryding!
    Mar 2017
    Just like my GL1800, a new tire makes all the difference in the world! Khumo ECSTA AST 225/50R15 installed - H rated and running 25 PSI. What a difference over the junk Kenda. Less wandering, smooths minor (and major) road hazards/bumps, incredible traction and corners like it's on rails! Can't be more pleased. Here is a the video clip that I played on the GL1800 site when I got a new tire on that bike. Glad to see it's also true with the F3T. Injoy!
    Jul 2011
    That was not my experience with the Kumho Ecsta tire. Installed one on my 2013 STL several years ago. I found it to be absolutely awful. Traction on gray pavement was bad and on wet pavement was simply terrible. Replaced it long before it was worn out because I could not take it anymore.
    I hope you have better luck.
    Mar 2017
    Maybe the F3 is just a different animal. Apparently it is different. With the Kenda - pin the throttle at a dead stop and the rear tire would spin and depending on the grain of the pavement, it would smoke . With the Khumo ECSTA AST 225/50R15 installed, it won't do that anymore . Don't know how I'm gonna impress the girls now . Traction just breaks my neck !!
    Wet? I'm 70 and ride for pleasure. Likely won't find out about that.
