Results 1 to 4 of 4
Thread: Help
    Mar 2019
    Lakeway, TX
    Question Help
    Could someone pls confirm if the headlights on the Ryker turn on with the bike off when you press the Engine Start Button? I know the DRL will turn on, but what about the main headlights?
    Thanks in advance!
    Very Active Member Tslepebull's Avatar
    Dec 2018
    East Texas
    Yes they do, when the engine kicks over
    2019 Ryler Rally , Shock Yellow
    Quote Originally Posted by FBRKR View Post
    It's probably the same as with the Spyders. The headlights are energized only when the engine is running except for a 20 second delay after turning off the engine. If the engine starts quickly it'll seem like they turn on as soon as you hit the start button. They're controlled by a load shedding relay to cut down on the heavy current draw while the starter is turning over.
    Mar 2019
    Lakeway, TX
    Thank you guys.
