Results 1 to 5 of 5
Thread: SE6 Shifting
    Jul 2015
    Dorr, michigan
    Default SE6 Shifting
    I have a 2015 SE6 and all I have to do is brush or breath on the paddle shifter to up shift. This causes unplanned up shifts at times.
    Is it possible to adjust the pressure required to up shift?
    2020 RT Limited , Petrol Blue
    Quote Originally Posted by Fatcycledaddy View Post
    I doubt it ….. It's not cable actuated …. it's electrical ….. Mike
    Jan 2017
    Bavaria, Germany
    This sounds like a defective switch or problems with the shift electronics. The best way is to take it to the dealer.
    Jul 2015
    Dorr, michigan
    I knew it was electronic, but I thought that maybe, like a brake light switch, the amount of travel of the button before contact to activate switch could be adjusted.
    Thanks for the responses!!
    I suppose that is possible …. but if you take it apart …. be very careful , I think there are springs in there …… Mike
