Results 1 to 15 of 15
    California
    Default Wrapped my ryker
    Tried some wrapping... Think it came out pretty good.
    Mar 2019
    Oviedo, FL
    Looks really good.
    May 2018
    MN
    Pretty!
    Kansas
    That looks fantastic
    Very Active Member robhowen's Avatar
    Apr 2015
    Tucson, AZ USA
    Looks great. What product did you use?
    Rob
    2015 RT-Ltd SE6 and F3S SE6, both with a number of commercial add-ons plus my own tweaks.
    California
    Thanks everyone... Here's what I used.
    Feb 2017
    Very nicely done. You must have good skills and exceptional patience.
    Jun 2015
    Ritzville, Wa
    Nicely done.
    Greg Kamer
    USAF, 20 years, retired
    2018 Can Am Spyder RT-Limited
    Active Member Micnice10's Avatar
    Jan 2019
    Rochester, MA
    Looks great!
    Apr 2015
    Tucson, AZ USA
    Super job! Looks like you did a great job on the slanted edges. I assume maybe a hairdryer or mild heat gun help. In any case, well done.
    Rob
    Mar 2019
    GTA, Canada
    Not bad at all .
    Mar 2019
    FL
    Very nice! How far under the edges did you continue the wrap? I've never tried it but I'm thinking of trying it on the Rally silver hood plate.
    California
    Only about 2 or 3 cm under as you're actually stretching the wrap at the edges which pretty much locks it in place. I'd suggest watching YouTube how to's on wrapping as my initial attempt (without watching videos) at wrapping the whole hood resulted in failure. The accent plate is good start for us newbies.
    And yes Rob a heat gun (and a sharp blade) is a must.
    Very Active Member Rogue Hawk's Avatar
    Apr 2015
    Chicago
    Quote Originally Posted by Ryke View Post
    That is also true for the zombie apocalypses.
    2019 Rally , Black
    Nov 2015
    Myerstown, Pennsylvania
    Very Nice! I think the carbon fiber look is great. I put some on my glove box.
    The Critter 2016 RT-S
    Cat Bypass from Lamonster
    BajaRon Sway Bar
    Hella dual horns with relay
    BRP Hitch with trailer module
    Foam Grips
    Adjustable Air Deflectors
    Shorty antenna
    Ultraguard half cover
    Gremlin bell from my son
