Any options to add Hazard lights to North American Rykers?
Has anyone seen options to add hazard lights to the ryker North America version
Wow...!!
Didn't know it had none....if they are still running the flashers through the instrument cluster could be difficult and you would have to wire up your own out side system.
I just avoid having hazards.
If you put the tryke in reverse, the lights blink just like hazard lights would.
Unfortunately it only flashes in reverse when the park brake is off.
I’ve got a Rally Ryker in the U.K. and discovered you can order the Hazard Switch made for the Russian market - part number 219400932. I ordered it and it is just the switch, bracket and wiring that goes into pins 5 and 6 in the connector block under the left hand fairing panel. Cost in U.K. was around £50
I wonder is simply adding the switch would be sufficient or if there are programming or other splices needed.
If you do make this mod please update us with the results. That is a mod I would consider doing.
There has been kits around for a long time to do this very thing
https://www.customdynamics.com/metric-4-way-hazard-kit
Yes but thats beyond adding OEM switch to a circuit designed to accept it.
The OP wanted options to add flashers, I gave him an option. What's the problem?
Maybe none. I’ve heard its not a good idea to hang things on a system using Can Bus unless made for it. None of my prior bikes had Can Bus but the Custom Dynamics unit is for incandescent or LED, not sure if it would introduce noise from the included flasher.
Current: 2022 CAN AM F3S SS. Manta Green, Route 129 windscreen.
Previous:CAN AM Ryker Rally. Intense black, side case , comfort drivers seat, comfort passenger seat with back r test, wind screen, LED auxiliary lighting.
