windscreen photos are on my flickr. they were to large to upload here.
http://www.flickr.com/photos/30938419@N03/
Ok now that looks good! Now I am going to my dealer tuesday and find out they haven't got one in and fail to tell me about it today if they had one in? Looks really good! And the rear cam is also cool!
Got mine the other day. Like the shield, the winglets, not so much. Up close they look like a tacked on afterthought, and tupperware on top of tupperware slows up maintainance, so I took them off. I will probably put them back on when the weather turns dirty, though.
I am looking into replacing my windshield also. I have a couple of questions for you. Where did you order your windshield from? Did the wind-deflectors come with the windshield? or was that seperate? Spyder is cool looking!!! Where did you get the back-up monitor from? Thanks
I ordered the windscreen back in december when it first was priced out so I got it for the 250. It did include the wind deflectors windscreen and all hardware. They are shipping out by my dealer in MA has about 4 still on back order. The back up cam I bought at advanced autoparts. 100 bucks for it. It is a wireless system and wred ito the rear license plate light so it is on continously. still playing with the location of the monitor though.
From who did you order the windshield? Thanks
How & where do the deflectors connect?
I ask because I'm about to place DZUS on all of the panels, but I'm concerned that the deflectors are tied into the bolts on the black panels. This may stack too much material for a DZUS clip
Also, I just installed the new BRP seat and sit a bit higher in the saddle. At 6'2" I wonder if the 25" windshield would be high enough? Which leads to the next question - would I do better with a CHAD 25" over a BRP, since the angle can be changed?
take a look at my photos. the brackets use the 2 screws that the 2 overlaping panels use. They have a rubber mounted strip to protect the finish also. The windscreen kit was purchased from my dealer in chelmsford ma. He has 4 still on back order
Thanks.
I may hold off on the DZUS until I get the shield.
You may want to install a...
I installed the 23 inch BRP but I wish I had installed a 25 or the CHAD which is adjustable. If you install the 25 CHAD you may want to see if someone that installed the BRP but did not install the deflectors wants to sell them. I've noticed that some install the wind shield but not the deflectors.
Right now we, my SO and I, are considering getting the CHAD because it is adjustable which should stop some of the forehead buffeting. But having said that the 25 inch BRP might stop it. I do like the style of the BRP better because the widest part of the flare near the bottom goes all the way out to the edge of the turn signal. This dramatically increases the wind protection on the arms.
Thanks for the advice.
I like the adjustability of the CHAD, but I agree with you on the BRP style where you get more hand/arm protection. I rode into the beginning of December (Connecticut) last year and though I have heated grips the extra protection for the tops of my hands may be better than what the CHAD offers.
As for the head buffeting, I'm 6'2" and I have the short BRP windshield and the Scorpion 1000 helmet, I don't really experience too much. I think this has a lot to do with the aerodynamics of the Scorpion helmet; as long as I stay in line with the windshield, the buffeting is minimal, even at high speed.
You may actually experience a lot more head buffeting with a taller shield than the stock one, even with the Scorpion helmet. The strong part of the windstream coming over a stock windshield or a sport touring shield hits your body. You are less likely to notice buffeting there. A taller shield, that is not quite tall enough, at the wrong angle, or spaced to far away, will allow the strong part of the windstream to hit the top of the helmet, or even lower. Often this is due more to turbulence, and not the direct windstream itself. Having no wind pressure on the body or the rest of the head, combined with significant wind pressure hitting high on the helmet, results in the feeling of buffeting, especially as the neck muscles get tired the longer you ride. This is exaggerated if the air is turbulent. For whatever reason, steady strong pressure over the entire helmet doesn't produce this buffeting effect. Maybe somebody here that understand aerodynamics can explain this phenomenon better.
-Scotty
I am not a Aerodynamics Expert . . . . .
-Scotty
. . . . but I think you described it perfectly Scotty.
I actually get less buffeting with the short stock BRP windshield, though I get a lot more wind.
It seems to be a difficult equation to balance between the Helmet + Windshield + Rider Height + Speed. I still have not found the right combination.
Tom
Tom
Thanks Tom. You, and Scotty, have given me something to think about. I may try test driving a few of these shields, if I can, before I shell out anymore $$$$
They are a BRP product, just like your Spyder. You buy them from your dealer or some other vendor that sells BRP products.
Happy owner of Silver PE #1232
All The Gear All The Time - ATGATT
Gulf Coast SpyderRyders
Zero, if quick panel removal is a priority for you, these wind deflectors are a problem. They have an internal metal bracket which is too thick for 14mm Dzus, you would need longer. I'm not sure how long or if they are available. The bracket covers the joint between the "Can-Am" panel and the fog light panel. By preventing easy removal of the Can- Am" panel, it causes removal\ replacement of the oil reservoir panel and opposite side cooler panel to be a bit more awkward, as well. Finally, the screws supplied for the outside plastic of the deflectors require a 4mm Allen wrench ( go figure!) and the deflector itself is an awkward 3 piece affair. Some people have stated that the deflectors cause too much heat in summer ryding. I did not find that myself, but I mostly ryde in a northen latitude. I think the weather will have to be pretty cold before I put those ugly suckers back on my Spyder.
Originally Posted by Neez
Zero, if quick panel removal is a priority for you, these wind deflectors are a problem. They have an internal metal bracket which is too thick for 14mm Dzus, you would need longer. I'm not sure how long or if they are available. The bracket covers the joint between the "Can-Am" panel and the fog light panel. By preventing easy removal of the Can- Am" panel, it causes removal replacement of the oil reservoir panel and opposite side cooler panel to be a bit more awkward, as well. Finally, the screws supplied for the outside plastic of the deflectors require a 4mm Allen wrench ( go figure!) and the deflector itself is an awkward 3 piece affair. Some people have stated that the deflectors cause too much heat in summer ryding. I did not find that myself, but I mostly ryde in a northen latitude. I think the weather will have to be pretty cold before I put those ugly suckers back on my Spyder.
Thanks Neez.
Good info. I'll have to think about it a bit. Knee-jerk response is, I don't want anything else to add/take-off when working on the
I really appreciate the info. Thanks again.
Scotty I need more power...
Why is it, after I installed the new BRP 23" windshield my Hindle exhaust sounds more like a straight pipe on a Harley, it's quite loud.
Is it because the shield creates a dead space of air that will allow more ambiant sounds to be heard. Therefor not allowing the air to drown out the sound thats always been there previous to installing the larger windshield.
Scotty do you think that I should change out my 23" for the 25" so I don't get so much rushing air on the top of the helmet? I'm 5'10"
Motza
What did I just say???
Motza
I'm not Scotty but, yes... a large screen will allow you to hear things you didn't before. The next you know, you'll be on here talking about all of the engine noises you can now hear.
Funny you should say that ata dude, I just got back from a 45 minute ride into town without my earplugs and yes I heard the engine noises that I never heard before...Now I'm really confused...new engine noises, louder exhaust... maybe I should just go back to the Ultra touring windshield and I'll here nothing.
Motza
I am Scotty, and approve of AtaDude,s message. You will hear lots of things you didn't hear before with a larger or differently shaped windshield. As you get used to the new noises, you will discover more. Pretty soon it can drive you nuts thinking something new has gone wrong.
As to the air hitting the helmet, it is hard to say. In general, a taller shield will raise the wind about as much as it is taller, but air turbulence from the design can alter that. It also depends on where the air hits you. If it hits three inches down on your helmet, two more inches alone won't help, you need a different shape or windshield angle. That is why the adjustable shields are so handy. How the windshield works also depends a lot on how you ride. An effective shield at 55 mph at rural road speeds, may be windy and noisy at 70 mph on the slab. A shield that works at the posted speed limit may not work at 20+ over the posted.
-Scotty
