Results 1 to 25 of 45
    Danbury Connecticut
    Default Tire update. Just for info, not starting a discussion or argument.
    Some info to add into the mix on tires.
    I just got three new tires from Netzley tire.
    On the front, Derick installed two Kumho Solus KH16.
    On the rear, a Cooper MASTERCRAFT LSR Grand Touring.
    I've only got about 90 miles on them so far.
    On the back roads, the Spyder responded much better than with the Kendas.
    On the highway at speed, the Spyder handled like it was on rails.
    I'm looking forward to the Spyder Clutter in New Holland PA.
    My Gas Tank Is Full; My Bladder Is Empty
    Time To Motor On
    IBA #47122
    Jan 2015
    southern WI
    Well then...no discussion shall we have.....kind of a pointless post...but....
    Nov 2017
    San Francisco Bay area
    I don’t think it was pointless. He was sharing info that others might find interesting.
    2015 Pearl White RTL
    Baja Ron Sway Bar
    Russell Day Long Seat
    Strobe Brake Light
    Active Member bigbadbrucie's Avatar
    Sep 2015
    Chilliwack, BC. Canada
    What sizes did you get?
    2014 Spyder RTS-SE6 Cognac
    Tri-Axis Handlebars
    Sena SM10 BT Dongle
    Sena 10S Helmet Intercom
    Garmin Nuvi GPS
    Sirius Satelite Radio
    Bruce Erickson
    Chilliwack, BC
    Canada
    JMHO WTFDIK
    Active Member Mikey's Avatar
    Durham,Maine
    Danbury Connecticut
    Quote Originally Posted by bigbadbrucie View Post
    Kumho Solus KH16 Front Tires
    Cooper Mastercraft LSR Grand Touring rear
    Yes Mazo EMS2, just sharing information for others to use as they wish.
    This is why I don't post much on this forum anymore.
    Another a$$hat I have to put on my ignore list.
    Time To Motor On
    IBA #47122
    Nov 2017
    So fwiw we are doing our best for valuable members like you to want to come back and post. We will and are giving vacations including permanent bans to those that made this forum less than friendly and not what Lamont intended when he started the site. All the mods hope to see you and others post more.
    LeftCoast
    Baja Ron Sway Bar
    Strobe Brake Light
    Jan 2015
    southern WI
    Well I suppose it's just another example of taking something in the wrong context, but in any case...my reply was only pointing out that you weren't looking for discussion or argument.
    Nov 2017
    The greater question is what was the reason for pointing it out? Simply move along or thank for the post and everyone’s fine. Hopefully no one is posting for the sake of argument.
    Baja Ron Sway Bar
    Strobe Brake Light
    Feb 2019
    Portland, Oregon
    I for one, appreciate it when those who ditched their Kendas for another tire give us their impressions. Its obvious that the Kendas are problematic, to say the least and I wonder what possess BRP to continue using them. Two brands top the list of replacement car tires and some day, I will be making my choice, so post on all you who have made the switch and I will gladly read your comments.
    Nov 2017
    Quote Originally Posted by Mazo EMS2 View Post
    I hope you understand at this point no one took it in the wrong context. It may be one that you didnít intend but the context was clear.
    Ok Iím done, back to your regularly scheduled programming.
    Baja Ron Sway Bar
    Strobe Brake Light
    aka: akspyderman ARtraveler's Avatar
    NW Arkansas
    It's all good here. A simple mis-understanding. Everyone involved is OK.
    And yes, we are bending over backwards to make this an informative and friendly site. A few trouble makers have been given vacations and the BS level has been diminishing.
    We welcome back those who have felt bad about what some say and do. We ain't perfect, but we are working on it.
    Currently Owned: 2011 RT A&C SE5 (magnesium), 2014 RTS-SE6 (yellow), 2015 Vulcan 900 LTD
    Previously : 2008 GS-SM5 (silver), 2009 RS-SE5 (red), 2010 RT-S Premier Editon #474 (black) Pictures of 2008 and 2009 Spyders are in Alaska Albums 2009 and 2010.
    5 Spyders, 10 years, 145,375 miles
    Nov 2012
    North Las Vegas, NV
    But what size were the tires?
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    Harrington, Australia
    Quote Originally Posted by LeftCoast View Post
    I hope you understand at this point no one took it in the wrong context. It may be one that you didn’t intend but the context was clear.
    Ok I’m done, back to your regularly scheduled programming.
    LeftCoast, from another perspective, I did take Mazo’s post in a different context, so maybe the context is not as clear as you think it is. I thought it was just a humourous comment on not starting a discussion. We do need to be careful that we are not offended just “because we can be”, and without looking at a comment from different perspectives
    2016 F3 Limited - Setup for Tall.... 6'7", 330lbs, 38"inleg.
    Lamonster RIP Boards in Position#5
    F4 25" F3-L screen fitted to Madstad adjustable hardware.
    Russell Daylong custom seat with driver 1.5" rearset, 1.5" taller
    Lamonster Billy Club handlebars
    ECU Xtreme Stage 2 retune
    Bajaron Stabiliser Bar
    Wilber 630/640 shocks
    Kuhmo KH17 175/60 fronts-18psi / KU22 205/55 rear-20psi
    Nov 2017
    Fair enough, and thanks for the feedback, posting can leave a confusing implication sometimes.
    Baja Ron Sway Bar
    Strobe Brake Light
    Absolutely......and I can understand completely how you read it the way you did. English is a language that lends itself to misinterpretation. Anyway....as you said earlier....back to the tyre non discussion ... so what size were the tyres?
    Active Member stmike 1800's Avatar
    Mar 2018
    Ontario ,way up north
    I am looking for a tire for the rear ,be nice to know what size people are using .And why the change in size .
    Very Active Member AeroPilot's Avatar
    Nov 2012
    Pueblo Colorado
    Hi ThreeWheels,
    I am also running the Kumho Solus KH16s on my 15 RT in the 155/60 R15 size and have run a couple of sets on our Rts. We traded the wifes RT-S at 44,000 so not sure the longevity, but the ryde and handling as well as the balance with less weights was good. As always its good to know the sizes as we dont have Netzleys out here, but we can and could source the Kumhos and Cooper tires; its good to hear that there are choices out there. Right now we are running the General Altimax RT43s on the rears in the 215/60 profile and other than the good ryde, like the correction of speed to due to the slightly taller tire (greater circumference). YMMV
    07 Shadows, Aero, Spirit gone but not forgotten
    03 Harley Sportster, 07 RK moved on
    11 RT, 15 RT-S, current 15 base RT and F3T
    Nov 2012
    North Las Vegas, NV
    Quote Originally Posted by stmike 1800 View Post
    There are many including me who use the 215/60R15 size because there are many choices of tires in that size. I use the General Altimax RT43.
    2016 F3 Limited
    2019 Ryker Rally
    Danbury Connecticut
    These are the tire sizes. Sorry for any confusion.
    Kumho Solus KH16 Front Tires 175/55/15. These tires seem about an inch wider than the OEM Kendas. The Kendas had started to cup.
    Cooper Mastercraft LSR Grand Touring rear 215/60/15. This replaces a Kumho Ecsta I had tat was wearing out.
    If I remember, I'll post back in about a month with more impressions.
    Time To Motor On
    IBA #47122
    Feb 2019
    Portland, Oregon
    215 on the rear doesn't get it too close to the belt?
    There's usually MORE space between the belt & the tire with most 215's vs the 225 OE Spec tire; admittedly it's only going to be about 5mm per side or thereabouts, but it's still more!
    The increase to a 60 profile vs the OE Spec 55 profile usually makes up for the difference in nominal tire width, & on many 215/60's is just enough 'extra' sidewall height to increase the rolling diameter enough to make the speedo almost correct instead of reading something closer to 10% optimisticly!
    So what's to lose; a better range of tires in that size, better belt clearance, speedo & odo/trip meters closer to correct, more sidewall height to better absorb road shocks from pot-holes etc pounding your tail-bone, usually better tire life fm the taller tire too, and then they are invariably cheaper than the OE Spec tires too!
    2013 RT Ltd
    Feb 2019
    Portland, Oregon
    My mistake Peter. I was thinking 205 was the OEM width. I'm in the learning process here.
    Blue Springs, Mo
    I agree Kendas are a very bad choice. Change oil and change tires. Totally unaceppetable on any other vehicles. Running KUMHO directional on back . can am dealer will not help you in my neck of the woods KC MO. Go to where they sell sling shots have equipment and know how. I took new kumho tire and bike. they changed balanced installed rear wheel $150. US Very pleased ran great to Spyder fest in all weather. Can Am wants to sell tires is what I think. What a money maker for them. What a POS product for life depending and we have no spares. Safe riding everyone see you at the next rally.
    Mar 2016
    Astoria, Oregon
    h
    I bought a Federal Formoza FD2, 215/60R15 94V from my local Les Schwab tire store. They were even able to mount it for me. (A fellow biker friend who was willing to give it a try.) The reason why I changed was the higher mileage I expect from the standard tire. I notice no change in handling.
