Best Looking (cleanest) phone mount in my opinion
Lamonster bar clamp with quad lock motorcycle mount and case. My next step is working on wireless charging. Quadlock doesnt make water resistant wireless chargers si my plan is to use their car wireless charger and make it at least splash resistant.
Hello donhy,
this looks great. Which mount do you use (Quad Lock Mount Model)? How did you attach the mount? Thanks for the help.
Originally Posted by susfrat
Hello donhy,
http://www.lamonstergarage.com/can-a...amp-lamonster/
https://www.quadlockcase.ca/collecti...tor-motorcycle
https://www.quadlockcase.ca/collecti...rcycle-scooter
If you want to change security lever color:
https://www.quadlockcase.ca/collecti...ut-front-mount
Plus case for your phone
Nice set up....
It is a nice set up and thanks for adding the links so we can search it out... congrats
2012 RS sm5
Can you tell me what torque settings you use to tighten the bolts on the handlebar? I can find the order but not that. After riding yesterday I decided to adjust mine.
btw - I agree. I have one too.
I use my weaker hand as torque specs
torque is 28nm
Originally Posted by donhy
where did you buy that USB port for charging your phone?
2015 Canam Spyder F3-S SE6
Detachable Passenger backrest #219400703
Gauge Spoiler #219400531
Blue Ridge Windshield #219400746
Hood stripes decal kit #219400711
F3 Idler Pulley #219800431 / Lamonster roller upgrade
Bajaron SwayBar
Elka Stage 2 rear shock
Arc LED fog lights
Lamonster F3 bar clamp with Quad-lock phone mount
Foam Hand Grip Covers
Tufskinz Peel & Stick Tank Protector Pad (Glossy doomed carbon)
Did you have to drill to enlarge the hole? also it wire directly to the battery, and you capped the switched ?
Yes and also wired a quick disconnect plug
Bajaron SwayBar
Arc LED fog lights
Wow it looks really nicely done. I’m not the geek guy. By could you please directed me to where can I buy all that please? Thall those quick disconnect plug.
Amazon as well
https://www.amazon.com/MUYI-Waterpro...ick+dis&sr=8-3
Bajaron SwayBar
Arc LED fog lights
just so I understand it correctly. You take those 2 red and black wire from MUYI 5kit tie it with the 3.0 car charger right, then you connect the other end of MUYI 5 kit with one of open harness at the trunk are?
by the way what kind or size of drill bit that you use to enlarge hole?
