Results 1 to 8 of 8
Thread: Mirror
    Jul 2016
    Bronx NY
    Default Mirror
    Hey guys Have a question. My right side mirror on my 2015 ST Limited, Shake a lot, here's a photo of the mirror and it seems to be opening up at the seam. Has anybody had this problem and what can I do? No Magnets for ST's Thank You.
    2015 ST Limited , Blue Demin Satin
    Certainly looks like the mirror casing is coming apart! Have you tried removing the mirror & seeing if the covering sections are all fixed properly?
    Active Member ARNIE R's Avatar
    Mar 2017
    Leesburg, VA
    Bottom piece looks like it is in place. The top looks like it is being "pushed" up. Make sure the wiring harness is sitting inside properly. It is a tight fit, but if it isn't laying down correctly, it may be be contributing to the misfit.
    2014 ST-S Cognac
    2014 ST-S , OEM Yes Cognac
    Bossier LoUiSiAna
    Quote Originally Posted by ARNIE R View Post
    when I replaced mine with the chrome accents there was not much there to lock in place careful when removing as the springs clips brake all too easily. I believe there were 2 little screws barely accessible behind the mirrors(not 100% sure) will look if I still have the info somewhere. *note did not have to remove mirrors to install, just the wind deflectors* & with yours separated it can get water & dust in around the led blinkers , ya you need to seal & or fix sooner.
    Found the info FYI you need to remove the lower 1/2 first; this gives access to the screw holding top 1/2 on. 39FB8CAF-002F-4B41-BA6C-A0F2AC304DD4.jpg6782AA52-102E-4BBC-B7EA-51E9FE79BC33.jpg
    A84C15D3-EBBF-4FB9-85C9-8BE7890C7E4D.jpg it has a note on pic 3 * “make sure she’ll is well inserted into support screw” P1 is the shell 1 is the support screw: looks like where you’d came off. Hope this helps
    Bossier LoUiSiAna
    Any update??
    Jul 2016
    Bronx NY
    The Mirrors on the ST are different then the one's on the RT's Clips on RT are on the mirror mount on the ST on the Bike.IMG_20190529_151727.jpgThat' s the new clip I replaced the old one.
    Jul 2016
    Bronx NY
    Mar 2017
    Leesburg, VA
    Quote Originally Posted by Emilio Velez View Post
    Yes, that top clip is the weakest link in the system.
    2014 ST-S Cognac
