Results 1 to 7 of 7
Thread: Running Hot
    Nov 2015
    Elida Ohio
    Default Running Hot
    Have a 2015 f3s that was a little low on coolant this early spring added the orange Gm dexcool and now is overheating mainly so if stopped for any length of time seems alright when moving at speed but definitely heats up fast at a stop light etc Thoughts?
    Nov 2012
    North Las Vegas, NV
    More info please. Does the gauge go up? Does it overflow coolant? Do the fans come on? Have you cleaned the radiators? Four screws and the grill comes off and you can see the radiators. (they tend to clog with debris).
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    Nov 2015
    Elida Ohio
    Cleaned the radiators last fall the bars go up at stops or slow speeds fans do come on and it’s actually cool here 50 no overflow I did buy the extended warranty at least
    Feb 2019
    Portland, Oregon
    Thermostat stuck open???
    Very Active Member stmike 1800's Avatar
    Mar 2018
    Ontario ,way up north
    Would not warm up,stuck close will give you over heat.
    2018 RTL , dark blue
    Very Active Member samewok's Avatar
    Oct 2011
    Jacksonville,Ar
    Did you use a pressure washer? if so you may have closed off some of the vanes.
    4" Stubby antenna, Dual arm LEDs Fender LEDs, Back Rest, Luggage Rack, Run, Brake and Strobe for top case, Mirror LEDs,Back Off decal on mud flap, reciptal for Battery Tender and Heated Gear, mirror LEDs that stay on or work with blinkers, GPS, side bag red LEDs, Top cuff with Ram Ball phone holder And USB power, Top cuff with drink holder and passenger cup holder. Also grilles in front of radiators, also spyclops. Garmin 595 GPS, Freedom windshield. Also glove box console And trunk wrap in carbon fiber from wrap my spyder. BRP comfort seat. added garage opener with rocker switch in center console to match other switches. And I have added Elka stage 2 shocks.
    15 rt , yes Black
    Active Member Ex Winger's Avatar
    Apr 2015
    Brockville ONT
    To start with make sure you have no coolant leaks.If that's good I would drain and flush the coolant system not good to mix coolants.
    2018 RT Anniversary , Brake pedal extended
