Page 1 of 4 1234 LastLast
Results 1 to 25 of 94
    Mar 2013
    Default Vredestein Quatrac 5
    Just got shipment notice that my new rear tire in 205/60R15 size will be delivered next Tuesday
    Ordered on March 27th from Vulcan Tire. It's a special order item, but will be worth the wait assuming it will handle like the fronts do!
    2021 Sea To Sky, 2020 RTL
    but our benefits don't?
    2015 F3S , White & Blue
    USA
    I'm in the same boat, waiting on the rear. I ordered the V rated, figured the tolerances may be held closer so it may not need as much balancing weights. Not sure of this though.
    h0gr1der
    Mar 2013
    I just checked Valcan Tire's web site and they now show both the H and the V version in the 205/60R15 size in stock.
    Medway Ohio
    Excellent tire!
    Approaching 10K on em.
    On my front drive Toyota Sienna.
    Quiet, smooth, took hardly any weight.
    Road force indicates virtually no variance side to side.
    Gor me thru deep 8" snow with no problem
    Good luck with them on your Spyder!
    Quote Originally Posted by h0gr1der View Post
    The speed rating should have no difference ........... the quality of the tire is what matters ..... Here's something interesting - the General Altimax RT 43 has a better rating in the lower " speed rating " than the higher ones ???? ... I have no explanation for that .... it just is ..... Mike
    USA
    I'm making simple ass-umptions here. V rate is good to 149 MPH continuous, while T rated is 118 MPH continuous. At very least the quality control has to be better. But I may pay the price in extra weight. The higher speed rating may mean more reinforcement, hence more weight. I'll weight the V rated and post the specs against the Kenda when I get it.
    h0gr1der
    KENDA - that tire is a joke compared to even the lowest rated auto tire ...... Mike
    USA
    I concur wholeheartedly.
    h0gr1der
    Nov 2008
    las vegas, nv
    So much for getting quatratec all around.
    When I mentioned tires were not exactly the same size, wider upfront and narrower in the rear when I was setting appointment at the dealer, they said they will only install tires that are same size as kenda, what’s embossed on tires not the actual size.
    I didn’t wanna do it but now I will have to go with 2 different brands, front and back.
    6 states down 42 states to go
    Mar 2013
    Quote Originally Posted by aka1004 View Post
    Wow, but not surprised. I always take off my wheels and bring them to an independent tire shop with my tires where they mount them and no hassles.
    Mar 2013
    Quote Originally Posted by PW2013STL View Post
    Update,
    I did get my tire and 2 additional ones that I did not order. Sent the suppler an email about this, but have not heard back.
    USA
    Hope you didn't get mine, I have a 205/60R15 Vredestein coming in by the 14th. Took them over a month to process the order!
    h0gr1der
    Sep 2015
    Chilliwack, BC. Canada
    A link to a Canadian supplier for the Vredestein tires was posted on this site, I went to it today, and just ordered my 2 front tires...I have not had confirmation as to when they will be shipped yet.
    Tri-Axis Chrome Handlebars
    Sena SM10 BT Dongle
    Double USB Port/Volt meter
    LaMonster Magic Mirrors
    BajaRon Swaybar
    HALO Skid Plate
    Shorty Antenna
    LaMonster Cat Delete
    Akrapovic Muffler
    FOBO2 TPMS
    Rear Trunk Rack
    Bruce Erickson
    Chilliwack, BC
    Canada
    2014 RTS-SE6 - Cognac
    Jan 2019
    North Carolina
    AKA 1004, don't know you situation, however, when the dealer told me he would only install the same size as on the Spyder, I would have gone to a dealer that would, and make sure he knew it!
    May 2016
    Ontario, Canada
    A dealer up here was the same.... must be an exact OEM size match. Ordered Toyo Proxes 4 for the rear and Fed. Formosa AZ01 fronts.
    I think your DEALER is really, really clue-less ….. because He doesn't even know the Kenda's are different sizes also ….. RUN from that Stealer ...….....Mike
    Quote Originally Posted by bigbadbrucie View Post
    Hey Big Bad it would be nice if you posted the Suppliers info ……. Mike
    Sep 2015
    Sorry Mike, my bad. Supplier is Quattrotires.com. They appear to be in the province of Quebec, probably Montreal.
    Sena SM10 BT Dongle
    BajaRon Swaybar
    HALO Skid Plate
    Shorty Antenna
    Akrapovic Muffler
    FOBO2 TPMS
    Rear Trunk Rack
    Bruce Erickson
    Chilliwack, BC
    Canada
    Nov 2008
    las vegas, nv
    I was thinking about attending spyder Jam in Cuba but cowtown will not install ANY car tires in front.
    May be I should expand my search area to Dallas...
    99.8% of the folks here, take the front wheels/tires off themselves, and take their New Auto tires to any car repair or tire installation shop and have them switched ….. and Usually spun balanced also …… Only dealers will remove and replace wheels / tires from a Spyder …… Mike
    Quite a few Canadians, should Thank You for this info …… I have been told by quite a few No One sells Vredesteins ……. Mike
    Active Member SteveandBelinda's Avatar
    Canton, MI
    I took my front tires/rims to Discount Tire along with the new tires, and they didn't have a problem mounting the new ones.
    2014 Can Am Spyder RT Limited - Pearl White
    2010 Can Am Spyder RT - Full Moon
    Mar 2018
    Ontario ,way up north
    https://www.tiresandco.ca/Quatrac in Canada,shipping can be expensive unless you buy 4 then it is free.
    2018 RTL , dark blue
    Active Member Cleg's Avatar
    Apr 2012
    Queensbury, NY
    From experience no issue with different brand tires front and rear. Currently Vredesteins in the front Kumho rear.. no issues at all AND what a difference with the Vs on the front...completely different and better ride! Just sayin...
    Quote Originally Posted by Cleg View Post
    This is Mandatory when mounting tires : " Tires on the SAME axel must be the SAME " ……" NEVER mix Radials with Bias Ply ", " NEVER mix Different types of tires with each other " ….. Mike
