Results 1 to 6 of 6
    Meadville,Pa
    Default New Spyder RS Se5 owner
    First time spyder owner here. Just bought a 2011 RS SE5 WITH 3300 MILE at start up check dps scrolls across screen, but check engine does not come on steering seems to be working properly. Been told a weak batery will cause this. It starts right up and seems strong. Can anybody help me out. THANK YOU.
    Mar 2017
    Salisbury,NC
    I have seen posts that weak battery can cause this. DPS takes uses a lot of power. Check battery connections to see if any corrosion and see if tight. Even if new battery, like last year, its been sitting and could just be weak enough to start but cause codes to pop up. Check with volt meter at rest and running. Rest should be 12.5, running 13.0 - 13.5
    former NE Ohio dude!!!! Ashtabula County
    Meadville,Pa
    Ok thank you for the info!! Hoping it is just the battery!
    Very Active Member JerryB's Avatar
    May 2014
    Beaverton, Oregon
    Hi Meadvillesypder,
    Re: Can anybody help me out.
    I cannot help you with that. However, here is some general info for you:
    Oil Change Tips:
    https://www.youtube.com/watch?v=u3oFWG2ZPOw
    https://www.youtube.com/watch?v=rwqxwRwSklM
    Changing the coolant:
    https://www.youtube.com/watch?v=a3YztJp2Vjw
    Frunk Removal:
    https://www.youtube.com/watch?featur...&v=p_JXqJhZCw0
    Sway Bar Install:
    https://www.youtube.com/watch?v=li0_Is7K3MM
    Breakdown:
    https://www.youtube.com/watch?v=YKhPGwkp0JQ
    http://www.spyderlovers.com/forums/s...pdated-Version
    Other:
    Headlight changeout GS/RS:
    https://ourdiyblogs.wordpress.com/20...t-replacement/
    GS/RS Air filter change & airbox removal:
    https://www.youtube.com/watch?v=CqIpzubAvyY
    GS/RS rear wheel removal:
    https://www.youtube.com/watch?v=MfPM__iTTNs
    GS/RS Battery Tender Installation:
    https://www.youtube.com/watch?v=cCJ-9ANbA4c
    GS/RS Coolant replace & fill:
    https://www.youtube.com/watch?v=ATOy3es1or0
    GS/RS Spark Plug & Wire change :
    https://www.youtube.com/watch?v=VtcqXjtt57E
    GS/RS Exhaust gasket replacement:
    https://www.youtube.com/watch?v=2E3v6cX_gmQ
    GS/RS SM-5 Oil change:
    https://www.youtube.com/watch?v=k2SrpTUVzZA
    GS/RS Rear brake pad replacement:
    https://www.youtube.com/watch?v=NnKVCGc4cLw
    GS/RS Front brake pad replacement:
    https://www.youtube.com/watch?v=YjuzW50zAZ4
    GS/RS Rear Shock Replacement
    https://www.youtube.com/watch?v=vJ7Hz5M3KEc
    Jerry Baumchen
    'I'll never forget what's her name.'
    'Things are more like they are now than they ever have been before.' Dwight Eisenhower
    2008 GS SE-5
    Nov 2015
    Chardon, OH
    Hey Jerry. That was a fantastic post. Very helpful to new folks....and to old folks.
    Hey Meadville. Yes, a DPS will sometimes fail, but the vast majority of issues are just what Woodaddict said - an aging battery that can't keep up with the demands of the DPS, or loose / dirty battery connections, or even the fuse. And sometimes the DPS system can be misunderstood. It's not like typical "power steering" that we're used to. This is an operational description from the shop manual. We're usually at Eddy's - out by the airport - a few times a year for foot-longs. Maybe will see you there.
    Doug
    ”Freedom is not a loophole”
    May 2014
    Beaverton, Oregon
    Hi Snowbelt,
    Re: Hey Jerry. That was a fantastic post. Very helpful to new folks....and to old folks.
    We are here to serve.
    And what is really nice is that it does not cost me anything.
    Jerry Baumchen
    2008 GS SE-5
