Page 2 of 2 FirstFirst 12
Results 26 to 50 of 50
  1. #26
    Aug 2013
    SF Bay Area
    2018 RTL and no problems with FM reception. Don't use it much as the stations are no longer as strong as they used to be. Went from San Jose to Victorville and with BRP C acting up I used FM and did pretty good all the way.
    2021 F3 Ltd , Magna Red
  2. #27
    Jan 2021
    northeast pa.
    Quote Originally Posted by hardpaul View Post
    My 2018 F3-T gets terrible reception also. When it autoscans for radio presets it only finds one station, and I live in the middle of DFW.
    my new 2020 F3 limited , i just get one station on autoscans, and nothing else ,,,
  3. #28
    Mar 2019
    Ruidoso Downs, New Mexico
    Crud! I thought I'd find a quick fix to the problem with my 2020 F3L but no cigar. I guess I'll try the ground strap check and a longer antenna if I can find one. I agree that the radio reception sucks!
    2020 F3L; gone but not forgotten are all the good miles!
  4. #29
    Mar 2021
    Arizona high country
    my 2018 F3L gets pretty good FM reception. I pull in a good FM signal (no static or fade) from over 75 miles away
  5. #30
    Active Member mcalva's Avatar
    Nov 2016
    Viladecans, Barcelona, Catalonia, Spain
    I know it is an old thread but due to various problems and the pandemic had not been able to test it properly till now.
    F3 2018 Ltd. I don´t have any problem with FM. I would say the volume is much louder than the Bluetooth signal I don't know why.
    2018 F3 Ltd. , Black/Dark
  6. #31
    Jan 2021
    northeast pa.
    Quote Originally Posted by McRuss View Post
    i told dealer about the bad reception, he said to stop in, when im in the area, and they would look at it, i havnt gotten there yet, will see what they say, and get back to all..
    2020 F3 limited, liquid titanium
    grip puppies
    Bajaron sway bar
    lamonster belt dampener
    battery tender
    19 in freedom tinted windshield
    matte black daytona frunk wrap
    Quadtrac 165/60's
  7. #32
    May 2021
    Louisiana
    Just purchase a 2021 RTL Sea to Sky. I was only able to get two channels when I accomplished the FM Scan. Took it back to the dealership and we discovered that cable from the antenna makes a connection to a cable from the display unit under the passenger seat. This connection was buried under the wiring in the seat pan and had not been connected. Once connected everything work correctly.
  8. #33
    Ohio
    Billy
    The FM reception on my 19 F3L seems to be ok. However, I have to turn it up so loud to hear it, with helmet, wind noise, etc. that I just use my Cardo intercom with ear buds.
    Poasttown
  9. #34
    Active Member lugnut1009's Avatar
    Nov 2018
    Mississippi
    Make sure you have the latest update on your cluster. I found out that you have to not only have buds connected to the bikes OBD terminal but also a double male ended USB cable connected to the cluster in the top console pocket to update the cluster software. That usually helps a lot with the low volume issue.
    Mine: 2016 Indian Springfield & 2021 Indian Roadmaster
    Wife: 2018 Can-am Spyder F3 Limited Pearl White
    2018 F3 Limited , Pearl White
  10. #35
    Mar 2019
    For clarification, my F3L is a 2020 and the antenna mount may be different. But here is my 'potential' solution: a signal booster that goes in line. Since the 2020 (and maybe 2019) F3's use a small antenna lead with odd connectors, I ordered adapters from Amazon along with the booster, total cost less than $30. I'm hoping this will help. IF not I may try replacing the antenna with a longer one. The 3L antenna is attached to the top box but three screws allows access to it and will make replacement fairly easy.
  11. #36
    Durham,Maine
    Have you tried taking the antenna off and cleaning the crap off the mating surfaces and threads and putting it back together? They love there Loctite!
    2012 RTL , Pearl
  12. #37
    Mar 2019
    I did check the ground strap and it was clean of Loctite and a nice shiny bolt surface (and the bolt did not bottom out...) I'll pull the antenna when I install the booster and check for Loctite there.
  13. #38
    Durham,Maine
    Can't hurt!!!
    2012 RTL , Pearl
  14. #39
    Mar 2019
    Didn't hurt but....there was no loctite interference.
  15. #40
    May 2021
    PA
    Just picked up a 2021 RTL. FM reception is very weak. Will only pickup one station. Where about is the ground strap? I was going to pull the short antenna to make sure it has a clean connection but not sure how to remove it. Going to look at the connection under the passenger seat as in post #32.
  16. #41
    May 2021
    PA
    Just went out and looked for the connector under the passenger seat. Found it tucked down in a hole under the seat pan. It was connected.
    I pulled it apart to look at the connection. The connection didn't seem fully seated. Looking inside the connector going forward to the radio. The female PIN inside that connector appeared bent over not allowing the male PIN in the antenna lead to connect properly. I used a pick and eye glass screw driver to straighten it out as best I could. The connection seemed better and locked when I put the connection back together. Tested the radio. Reception seemed a lot better. The other presets I had were coming in now even parked in the garage. Will know more next ride when rain passes after today.
    Worth checking out for those having this issue. Could have happened when the Spyder was assembled at the factory or a defect in the wiring connector. The antenna lead going to the radio appears to go into the Spyder harness going forward. Doesn't look easy to replace the antenna lead forward to the radio. Not sure how hard it would be to replace the connector itself.
    Will see if this solves the FM reception issue on our Spyder. Will mention next time into the dealer.
    Craig
  17. #42
    Durham,Maine
    There was on my old ride, maybe they have been reading our posts from the past!!
    2012 RTL , Pearl
  18. #43
    May 2021
    PA
    FM reception issue appears to have been solved on the 2021 RTL by correcting the issue at the connection under the passenger seat.
  19. #44
    Very Active Member pidjones's Avatar
    Mar 2021
    East TN
    Quote Originally Posted by cef2lion View Post
    I checked the connector, but it was fine. Still lousy reception on my '21 RTL. Considering finding a 31" whip to replace the shorty. Mounted so low and far back, a longer whip shouldn't interfere with our garage door or passengers, just maybe something to watch for when passing something to the left out of the trunk. I'll be looking for a black one with the spiral wind noise prevention.
    1976 RD400c
  20. #45
    Jun 2021
    Dunsford Ontario
    Quote Originally Posted by lugnut1009 View Post
    When I took her trunk off for the trailer hitch wiring and then again to add her rear LED’s I did take that strap loose and clean it, but I didn’t notice the bolt bottoming out, I thought it tightened up. I’ll check that out again.
    Today I took her antenna apart and cleaned it. Then I ohmed from the wiring connector to the stud and had 0 ohms so I knew it was a good connection. It wasn’t bad looking to start with though.
    Have the same issues on my new 2019 f3 sounds like crap . I ‘ve gotten to the point where I just shut it off it’s so bad.going to use Bluetooth now see how that goes.
    Ken (190243)
  21. #46
    Member wtmc's Avatar
    Jun 2021
    North Carolina
    I have a 2021 RT, and found the problem. Antenna cable under the passenger seat was disconnected.
    2021 RT , Petrol Metallic
  22. #47
    Jul 2021
    New Brunswick
    I have a 2018 F3L. The FM radio reception simply sucks and is unusable. It's been this way from driving out of the dealers lot brand new. This is a big difference from my previous ride a 2013 STL. The radio reception was good on it. The dealer has looked at it once and agrees it sucks but was unable improve it.
    So my question is. For those of you with a 2018 or 2019 models. F3 or RT. How is the radio reception. I am not interested in 2017 or older model years. Different beast. What I am trying to figure out is if there are some out here that are working fine and I just need to find out what's wrong with mine. Or maybe it's a F3 problem only. Because I have seen posts from RT owners that say their reception is ok.
    Your answers and comments would be appreciated, thanks.
    2019F3L very poor radio
  23. #48
    Mar 2021
    years ago I had an FM amplifier for my car radio. I wonder if something like that would help the Spyder?
  24. #49
    Mar 2021
    East TN
    The antenna connector was not the problem for my '21 RTL - it was made up properly. Cleaning locktite and paint didn't help, either. 15" antenna is the problem. Went to O'Reilly and bought a 31" replacement (black with spiral wrap to reduce wind noise), dug through tupperware to get to the mount, unscrewed the shorty and screwed in the new one with a ~1" x 6mmx1 stud I cut from a bolt. Much better reception. Built up the gap between the existing grommet and new antenna base with rubber tubing, a grommet, and shrink tubing. Looks factory.
    1976 RD400c
  25. #50
    Jun 2021
    North Carolina
    On my 2021 RT, after connecting the antenna cable, it works great
