Results 1 to 13 of 13
    Dec 2015
    Louisville Kentucky
    Default 2015 RT Front grills
    I received my front grills from Lamonster, how do I remove the existing grills?
    Default Not sure...
    As far as I remember you don't remove the originals but newer models from other suppliers could be different. If the instructions do not show or mention their being removed then theirs just mount in front of the OEM ones....
    Gene and Ilana De Laney
    Mt. Helix, California
    ​2012 RS sm5
    Dec 2015
    Louisville Kentucky
    Lamonster’s video shows them removed because he vacuums the inside.
    Quote Originally Posted by Benmannino View Post
    Just looked at the breakdown on cheapcycleparts.com and it may be a task to get them out of there. Looks like they are held in with screws between body parts but not sure if you have to remove the whole front panel around the frunk to get there. Maybe someone with a shop manual can help....
    ​2012 RS sm5
    Vermont
    Several years ago I purchased a set of grills( 1 with a spyder and the other with R/T ) these were installed in front of the originals. The original grills are still on the bike. I'll post pictures of mine. Here are some pictures: Spyder Grills RT 003.jpg Spyder Grills RT 001.jpg, Spyder Grills RT 002.jpg.
    In front of the originals there is a groove where the new grills would go.
    Deanna
    Gremlin Bell
    SpyderPops Missing Guard Belt
    Ultimate F3 Floorboards
    Sway Bar with Links
    Rolo Laser Alignment
    Half Cover
    Vermont
    Here are some pictures of the grills that I have on my spyder: Spyder Grills RT 002.jpg, Spyder Grills RT 003.jpg.
    Hope the pictures help.
    Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
    Vermont
    Here are some pictures of the grills that I have: Spyder Grills RT 002.jpg, Spyder Grills RT 002.jpg, Spyder Grills RT 001.jpg.
    Hope this helps.
    Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
    Very Active Member bcer960's Avatar
    Jul 2016
    Kamloops B.C.
    I have the same ones (spyder) as Deanna. Only change I made was, I figured the body of the spyder was still a large hole for debris to get in, so I put screen door mesh behind them. I used spray adhesive to attach the mesh to the grill. It's been 2 years, and 36,000kms, and the screen is showing no signs of coming off.
    2017 RT-S
    Bump Skid - Spyderpops
    Wrap - Wrapmyspyder
    swaybar - Bajaron
    Sena 20D & SM10
    3 PC Mesh Zippered Lid Net Set - TricLED
    A arm LED's - Safety LED's - TricLED
    Mirror Sequential turn signals
    Glo-riders
    LED rear turn signals and reverse lights
    Front Grills
    Third Brake light
    Larson Scanner
    Light Up - Sue Hopper
    Vermont
    Quote Originally Posted by bcer960 View Post
    The ( spyder) grill has a moth. The ( grills) are still look new. I have 24,553 miles on my spyder and still going strong!
    Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
    Dec 2015
    Louisville Kentucky
    Thank you guys, but if you you tube Lamonster it looks like the old screens have been removed, and he installs mounting plugs that you screw in the new grills. Also shows him vacuuming the interior.
    Jul 2016
    Kamloops B.C.
    The new grill go near the front of the tunnel. The old grills stay in place
    2017 RT-S
    Wrap - Wrapmyspyder
    swaybar - Bajaron
    Sena 20D & SM10
    Glo-riders
    Front Grills
    Third Brake light
    Larson Scanner
    Dec 2015
    Louisville Kentucky
    I rewatched the video, I was wrong I see that the screens are still there. Thanks
    Yep, I was going to post this but beat me to it ..... I DIY'ed my grills and made them removable, so I could clean the actual Radiators .... I actually removed the OEM grills from the inside with the Frunk off .... They are mounted early in the assembly process of putting the many pieces of the Frunk together .... I just cut them out ( very carefully ) and used the OEM mesh for my new grills ..... Mike
