bump skid use
I tried to see if there were any posts asking if you can use Spyderpops bumpskid for jacking up the front of a RTS Spyder using a car floor jack? Thanks
I wouldn't recommend it. The bumpskid is mostly just attached to the bottom of the frunk.
AKA Jud Smales, Four Year Spyder Ryder!
"Quando Omni Flunkus, Moritati"
The Critter 2016 RT-S
Cat Bypass from Lamonster
BajaRon Sway Bar
Hella dual horns with relay
BRP Hitch with trailer module
Foam Grips
Adjustable Air Deflectors
Driver & Passenger Gel Pads in Seat
Shorty antenna
Ultraguard half cover
Gremlin bell from my son
Break Stripe Kit from Wrap My Spyder
2011 RTS (Sold to a very nice lady)
1998 Honda Valkyrie
2006 Mustang GT. Varooooom!
US Navy Veteran
SC Law Enforcement Boat Captain
CNC Machine Service Technician
President: Rolling Thunder SC1
Member: Disabled American Veterans, Rock Hill, SC
Member: American Legion
Experience is recognizing the same mistake every time you make it!
only if you have a two prong jack, like a motorcycle or lawnmower type jack
Cruzr Joe
there are no posts asking that question because it is really silly. The bumpskid is not structural
Flatlander, Navy Veteran, Widower
Loved my 2014 RTS SE6 Pearl white
but have a new love now,
my 2017 RTS SE6 Champagne metallic (Champ)
Originally Posted by Grandpot
Absolutely no!
why would you want to?
2014 RTL Platinum
2014 RTL Platinum
If you have a car jack that can reach the back center where the bump slid overlaps the frame. What gives the skid strength is where it is screwed to the back into the steel. When I had Elka do my shocks that is where they jacked it up.
2017 F3 Limited
There you have it....
Though it is a pretty solid piece where it is attached to is not strong enough to support the wieght of the spyder. As you can see there is a weight limitation to what you can carry in the frunk and you can imagine WAY less that the weight of the front end of the spyder....
2012 RS sm5
