Results 1 to 9 of 9
Thread: Help ID Cable
    Aug 2016
    Beloit, Wi
    Default Help ID Cable
    Looking for help with a part number or where to purchase this cable for a 2014 RT
    Thank You
    Mark Light
    Live Long and Ride Hard
    Aug 2016
    Beloit, Wi
    Anyone know the part number or where I can purchase tis cable. 2014 RT
    Thank You
    Mark Light
    Nov 2015
    Myerstown, Pennsylvania
    Is that a USB cable or an IPOD cable? An IPOD cable is 710002676. I didn't find the USB part number yet.
    The Critter 2016 RT-S
    Cat Bypass from Lamonster
    BajaRon Sway Bar
    Hella dual horns with relay
    BRP Hitch with trailer module
    Foam Grips
    Adjustable Air Deflectors
    Shorty antenna
    Ultraguard half cover
    Gremlin bell from my son
    SoFlo
    Pretty certain that is a homemade setup. The two oem trunk harnesses were round style where they plug in, and either old style Apple or 3.5mm headphone style.
    At a guess, the same person that mounted the Sena Dongle in the trunk ran that extra harness.
    Dec 2015
    Oakley Utah
    What are you trying to accomplish? Maybe duplicating that cable isn't the solution.
    2014 RTL Platinum
    Aug 2016
    Beloit, Wi
    To use a usb drive for music
    Thank You
    Mark Light
    Jun 2015
    Hampton Roads, VA
    Try unplugging the SENA headphone jack? Maybe the radio is taking control over the USB input? Just a thought. I have my iPhone plugged in the USB jack, works fine. Also, just to be thorough - you are hitting MODE and selecting the USB input on the dash?
    Jul 2011
    Mitchell, Ontario, Canada
    Quote Originally Posted by zip3151 View Post
    A 2014 model is not capable of using usb drive. The radio is not capable of taking a digital audio file and converting it to audio. But it is capable of controlling a ipod. The ipod converts the audio file to analog audio to the radio.
    Very Active Member robhowen's Avatar
    Apr 2015
    Tucson, AZ USA
    It looks like it could be part of your GPS cable harness if you have something like a Zumo 590 or 595 as that harness has a USB, Audio In, and Audio Out leads that look very similar to what you have.
    Rob
    2015 RT-Ltd SE6 and F3S SE6, both with a number of commercial add-ons plus my own tweaks.
