Bluetooth intercom system with more than one mount?
I'd like to connect my phone via Bluetooth to an intercom system, but I have more than one helmet. I choose my helmet depending on the location of the ride and the temperature. Is there an intercom system that has multiple mounts so it can be moved from helmet to helmet? Thanks in advance for answers / alternative suggestions!
For bikes I think sena is one the best out there. You can buy the mount for each helmet and simply slide off the pod and you are set. The mount for the evo 20’s has the speakers, mount and mics all integrated together. It is relatively cheap around $40 a mount. Push the silver button and the pod slides right out and transfers to another mount. I do the same. I have a modular and 3/4-1/2 face helmet. Mounts and speakers in each just transfer the pod. I like the sena 20 evos personally.
I have a Sena SMH10. It has now been replaced with a newer model. But are setup the same. You can buy as many mounts as you want. There are different styles of mounts that may work better with different styles of helmets. All work with the same electronic pod.
2018 F3 LIMITED
You can say the same for Sena 30K as well. The same mount works for 20s and the 30k (and maybe other Senas). This is what I have.
Rob
2015 RT-Ltd SE6 and F3S SE6, both with a number of commercial add-ons plus my own tweaks.
Thanks for the responses. I'm looking at the Lexin LX-FT4 as an option and just googled up this https://www.lexinmotorcycle.com/acce...-headsets.html.
I have the Lexin LX-B4FM....works great and is cheap? You can use the clip mount and move the unit from helmet to helmet no problem.
We just bought the new Sena 30 after have UClear for the last 6 years and the Sena is far away the better, it also came with several mounts and three different mics. We ride with modular helmets and it works great with the boom mic.
I bought these for my son and myself - for the money cannot fault them https://usa.banggood.com/1000m-Motor...l?rmmds=search
You can buy the extra speakers and micro (cheap) and attach to each helmet (i did) and then just unclip unit from one to other -watch Canadian video on link also
SpyderLovers Sponsor
THIS ONE MAY BE THE EASIEST ONE YET....
I have everything you need to do what you want, Give me a call
9:00AM to 8:00PM Pacific time daily 209-887-3283
email me at motorcycledave@mac.com
You have many choices to pick from SMH10-10S-20S EVO- 30K and more
all on special sale pricing to Spyder lovers members
Ride Safe
Dave
Thanks again for all your responses! I will research all the suggestions.
Good Morning Sharon,
What ever system you choose ( we have Sena SMH 5 -- for years) SPEAKER placement is a very important consideration.
Lew L
Tags for this Thread
