Results 1 to 23 of 23
Thread: Brake failed
    Active Member ChrisW's Avatar
    Oct 2013
    Fernley, NV
    Question Brake failed
    Help, We have a 2014 RT and when we turn off the parking brake the light stays on and it says BRAKE FAILED. What can we do to fix it?
    The Wife's 2014 RTS SE6
    New tires: Back, KUMHO ECSTA 225/50 R15 (24psi) @ 9,380 miles, Fronts, KUMHO SOLUS KH16 175/55 R15 (20 psi) @ 9,421 miles
    Jul 2011
    Mitchell, Ontario, Canada
    With the key on and the brake failed message on the screen. Press mode, set and turn cancel buttons all at the same time. Some 5 digit codes will appear on the screen. Write them down or take a picture. Post here and someone will point you in the right direction.
    When you turn off the parking brake can you move the Spyder? If yes, check the brake fluid level, both master cylinder portions remembering that the forward most cap is for the rear brake, rear cap for front brakes. If no, the operator's guide says to have transported to nearest dealer. In that case you will have to manually remove the parking brake cable using a 12 mm open end or small crescent wrench. Loosen the lock nut, the rearmost one you can easily see, by turning it CCW and turn the adjusting nut, the forward and hard to see one, CW to loosen tension on the cable so you can slide it out of its bracket.
    Oct 2013
    Fernley, NV
    My dealer is CRAP here in the Reno area so I need to work on it myself. I just need to know how to remove the right side covers and I may be able to find it.
    Oct 2013
    Fernley, NV
    When we turn it off the brake is off and we can ride. However the light and Failure Brake comes on sometimes and then it will go off. This sounds like a switch/button that is in contact with that system is a little off of alinement. What do you all think? And how do I remove to right side panels.
    Oct 2014
    Fort Mill, SC
    If you were pressing on the brake pedal when releasing the parking brake, the pedal most likely went down further and activated the Low Pressure Switch.
    If you do not have any codes, but still have a brake warning, it is possible the low pressure switch has been activated. There are three switches in the brake circuit. 1. Brake light switch, 2. Hydraulic pressure switch, and 3. Low pressure switch (this is really a limit switch that just senses the pedal has traveled too far). This can be reset by the following procedure.
    After a low pressure switch (LPS) problem has
    been solved, it is necessary to clear the occurred
    fault in the VCM as fo llows:
    1. Turn ignition switch OFF.
    2. Wait 30 seconds.
    3. Turn ignition switch ON.
    rmr2011-086
    www.green-manuals.com
    4. Firmly press brake pedal until you hear a "click"
    from the LPS sw itch or until braking pressure
    reaches 3 500 kPa (508 PSI) .
    NOTE: The 1st click will come from the brake light
    switch. Continue to strongly press pedal to hear
    a 2 nd click. This one will come from the low pressure
    switch. You may not hear the click, just push the pedal real hard.
    5. Turn ignition switch OFF.
    6. Wait 30 seconds.
    7. Turn ignition switch ON.
    8. Validate fault was cleared.
    When I say press the brake pedal down, I mean do it really HARD!
    2011 RTS
    1998 Honda Valkyrie
    US Navy Veteran
    Member: American Legion
    Apr 2017
    North Central Florida
    Quote Originally Posted by ChrisW View Post
    NO. It sounds VERY much like a coincidence......and the brake fluid is a little low.......and it just looks like it is somehow related to the parking brake.......when it isn't at all.
    Check the brake fluid and add a tablespoon or so even if it looks OK.
    May 2017
    Mesa, Arid-Zone-A
    I would check brake fluid level first. You will get that warning when the fluid level is only a couple teaspoons low..... Jim
    Platinum Silver Satin 2014 RTL, SOLD
    Feb 2012
    Spring City,Utah
    If you look in your owner's manual it will tell you how to remove the panels and in what order.
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    Venture Riders
    TOI
    Oct 2013
    Fernley, NV
    This is what someone said on facebook: "Simple stuff first. Check you brake fluid. The reservoir is under the seat. It must be full full. I mean to the point where it almost runs out the top the sensor in there is very picky about that. Use DOT 4." what do you think?
    Very Active Member trikermutha's Avatar
    Sep 2014
    USA
    Have you done this yet as suggested to see if you have a code stored? Just wondering?
    Oct 2013
    Fernley, NV
    We tried, there is no light right now and there is no codes showing....
    Jul 2011
    Codes will only show when they are active. That means while the brake failure message is on the screen.
    ...And how do I remove to right side panels.
    Have you checked the brake fluid level? Please do yourself a favor. First, read the bottom of pg 144 of your operator's guide, Second, see pg. 135 -136 of your guide to see how to check the brake fluid level including the orientation of the vent in the caps which should be at about 11 o'clock, pointing toward the right brake light, if you are standing on the right side of the Spyder, driver's right looking down at the caps. If the vents, a distinctive bulge on the top of the caps, is not pointing at 11 the caps may have losing fluid because of the downward tilt of the master cylinder reservoir and the brake fluid level may be low. If you have to remove panels read pg. 48-52 of your guide; the instructions for all panels are there. If you have to add brake fluid cover the painted Tupperware with impervious material as brake fluid will destroy the paint. You should use something like a teaspoon as the reservoir doesn't hold a lot of fluid and the low level sensor is very sensitive. If you still believe you have to remove panels and know how to use a volt meter, look at post #7 of this link: https://www.spyderlovers.com/forums/...-won-t-Release.
    Feb 2019
    Portland, Oregon
    Even though I bought mine new, but as a left over 2017, because of above admonishments to check the brake fluid level, I did that and I was surprised to see murky fluid. In just 2 years, the fluid had absorbed enough atmospheric moisture to darken it - just sitting dormant. This is why you change the brake fluid every 2 years, at least.
    If you remove the cap and can not see clearly the round screen at the bottom of each compartment, change the fluid.
    A short cut, without bleeding, is just suck out the fluid in the reservoir and replace with fresh DOT4.
    Apr 2017
    That really is NOT a good option.
    A fair amount of contaminated fluid will be left in.....partly because of the ABS hardware......and if there is any "dirt" present, it has no chance of getting out.
    Feb 2019
    Portland, Oregon
    Understood, but I go on the operating table tomorrow and removing what's in the reservoir and replacing with fresh is better than doing nothing. The fresh fluid will eventually absorb some of the moisture from the fluid that's in the lines.
    Oct 2013
    Fernley, NV
    OK, I am looking at the caps if I am sitting on the bike the vents are pointing to the right handle bar grip, or 1 on a clock. As you said how can they be pointing to 11oclock but at the right tail light?
    Oct 2013
    Fernley, NV
    Do you have any pictures of the caps on, as the book is real bad on the picture of the right/wrong way to put the cap back on.
    My apology for not being more precise. What I meant to say was stand on the right side of the vehicle. (Left and right are always used in reference to the rider sitting on the Spyder.) So, you're on the throttle side of the Spyder looking to the rear of the machine. If you look down at the master cylinder, in reference to a clock 12 o'clock is facing directly to the rear of the bike. The vent is pointing at 11 o'clock, or in the direction of a line from the center of the cap to the right rear taillight.Master Cylinder Cap.jpg. Now in the picture, the top of the picture faces to the left side of the Spyder. You can see the vent on the cap between the C in the word "CLEAN" and the G in the word "REMOVING." Sorry, I don't detail my master cylinder.
    If the vents are pointing toward the throttle, as you say, they are pointed in the wrong direction and you may have lost brake fluid out of the vent since the master cylinder slopes downward from rear to front. The loss would be very gradual until the level triggered the low fluid sensor. Hope this clarifies things a bit more for you.
    May 2017
    Mesa, Arid-Zone-A
    JayBros..... Thank you for the detail description. Very informative. And, I checked the caps on mine and they are incorrectly installed. The vents are (were) pointing towards my right handlebar (throttle). I should have paid better attention. The entire area around the caps was coated with a lot of gunk. I added about a teaspoon of DOT4 to each. Cleaned and fixed now..... Jim
    Oct 2013
    Fernley, NV
    Thank you for the rest of the info. I am keeping the clock set from the riding position thus the cap vent part will now be in the 5oclock position pointing towards the right tail light. Will work on the brake fluid today as I need to get a new bottle of DOT-4 first. Thanks to all....
    Oct 2013
    Fernley, NV
    I added a little brake fluid in both and put the caps on the right way. Now we just need to go ride it. Thanks to all
