Results 1 to 14 of 14
    Apr 2019
    Florida
    Default 2019 F3 Limited Rear Turn Signal Bulb
    Anyone with a 2019 F3 Limited, can you tell me the bulb type or number of the rear turn signal bulbs? For example, is it an 1156 socket type or one of the newer push in type bulbs. Thanks.
    2019 F3 Limited , Big Bike Parts full size pedal Black Metallic
    Bay of Plenty New Zealand
    Quote Originally Posted by rdkarl View Post
    Read your manual all that info is in it.
    Apr 2019
    Florida
    Quote Originally Posted by Bruce B View Post
    The manual only states the voltage, and wattage of the bulb, not the number. Thanks.
    Nov 2012
    North Las Vegas, NV
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    Active Member cyclekid58's Avatar
    Sep 2014
    Post Falls Idaho
    Found that to be true for the RT as well, bulb itself had the number on it. Replaced mine with LED.
    Greetings from Idaho
    2014 RT-S,
    Barjaron swaybar, chome luggage rack, Ram Mount GPS, 12 volt dash outlet, spyderflap mudflap, Rivco flag mounts, drink2go and custom handlebar drink holders,Driver Backrest,Tri-Axis Handlebars, TRICLed turn signal lights. Custon Dynamic Magic Strobe Brake Modulator, Triple Dash Pouches, "Squared Away" Laser Alignment, Spyderpops Bumpskid, TricLed "Knightrider" LED
    2014 RT , White (Mine) Cognac (wifes)
    Very Active Member campermac's Avatar
    May 2015
    Etters PA
    Has anyone successfully replaced the rear turn signal bulbs on a 2019 F3L and not have the hyper flash?
    I am being told that people cannot see the turn signals in the rear.
    I am also thinking of changing the color to red if there is an LED bulb that won't hyper flash.
    Thanks
    2022 RT Limited , Silver w/ Black and Purple accents
    Feb 2019
    Portland, Oregon
    I just installed amber LED turn signal bulbs and yes, they did hyper flash, but I watched Lamonster's video on how to cure it and it worked. It's really very simple, but a bit arcane.
    Active Member pieman9155's Avatar
    Aug 2019
    upstate NY
    i think it is 1157 blub i replace with led in my 2019 f3t but it hyper flash's
    2019 f3t , titanium
    Mar 2017
    1156 in amber.
    May 2015
    Etters PA
    RICZ
    So the Lamonster trick works on the 2019's?
    Jul 2011
    Mitchell, Ontario, Canada
    Quote Originally Posted by campermac View Post
    RICZ
    No.
    I guess my answer is too short so I am adding the rest of this useless verbiage so that Spyderlovers site will accept it.
    2018 F3 LIMITED
    Dec 2013
    RICZ
    No.
    Dammitall!! And here I was thinking that was what emoji's were for?!? Besides, it was World Emoji Day last Friday, 17 July!!
    Sorry, but I just hadta!! I've been waiting for a good opportunity to slip that 'World Emoji Day' news in, and there it was!
    So now I'll return you all to the regularly scheduled program, and hopefully my little foray/off topic post won't detract too much from the REAL thread topic here.
    2013 RT Ltd Pearl White
    Ryde More, Worry Less!
    Feb 2019
    Portland, Oregon
    RICZ
    It worked for me. FYI, the LED bulbs I used had some sort of circuitry that was supposed t prevent hyper flash. That prolly aided in the success of using Lamont's method. Here's a link to the bulb....
    https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    Jul 2011
    The procedure to calibrate the current load of the turn signal bulbs to prevent hyper flash. Only works on models with the color display from 2014 to 2017.
    2018 F3 LIMITED
