Results 1 to 13 of 13
    Member Bill's Avatar
    Apr 2019
    Saratoga Springs,NY
    Question Anyone done a front wheel Tire rotation?
    Hi all:
    I’m just wondering has anyone rotated the front tires on the Rt Limited..?
    Apr 2017
    Wisconsin
    Nope, never have. I would not recommend rotating the back with the front though not sure if people are swapping fronts from side to side, I myself do not, and don't see a point, in doing so.
    The front tires (OEM Kenda) on a Spyder/Ryker are directional treads. If you do rotate them...you have to change the rims too.
    Apr 2017
    Wisconsin
    The front tires on a Spyder/Ryker are directional treads. If you to rotate them...you have to change the rims too.
    Good to know.
    May 2017
    Mesa, Arid-Zone-A
    Well, now I have to go look. I didn't pay attention when I installed my front wheels after the new tires were mounted. I didn't give a thought about them being directional. Have to check it out in the morning..... Jim
    Couldn't wait till morning. Just checked and my tires are not directional. They just say "outside" on the outward facing side. Now I'll sleep better knowing that the Spyder is not shod incorrectly. BTW my tires ar Federal Formoza AZ01 175/55R15s..... Jim
    Last edited by canamjhb; 04-26-2019 at 10:30 PM. Reason: To get a good nights sleep
    Semper Fi
    Northern Kalifornia
    Shortly before I swapped out my directional tread OEM front tires for new and better tires, I rotated them and drove them for another 800 miles. Nothing happened nothing changed and nothing went wrong. I did it during the summertime.
    Feb 2012
    Spring City,Utah
    most of the car tires we put on out Spyders are not directional. Usually the directional warning refers to the original OEM tires.
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    Jun 2010
    Las Vegas
    I never bothered rotating the Kendas, but on my Formozas, which are asymetrical, I did rotate them when if I gad the bike on jacks gir maintenance. I got 45,000 miles on my last set of Formozas.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Quote Originally Posted by SpyderAnn01 View Post
    Ann this is interesting … my experience with wear on the front tires has been - with correct alignment the tires wear Evenly across the tread.….. The tire rotation thing is from BRP which normally doesn't sell the Spyders with correct Alignment ….. Mike
    Feb 2018
    NorEastern, Washington
    Probably didn't drive enough miles to notice the breakdown. But my guess is that it was happening. Driving directional tires in the wrong direction usually causes ply and tread separation over time. I have seen the results. Perhaps with the OEMs being only 1 ply, it may not be as quickly noticeable and may take more time for them to start bulging and getting out of round.
    Regards,
    Don
    2017 F3T , Triple Black
    Idaho
    Quote Originally Posted by dondje View Post
    The directional notation on most all tires is related to the tread design and water shedding, not any tire construction characteristics. As least that's what I found when I did some research about it.
    2014 Copper RTS
    Nov 2012
    North Las Vegas, NV
    The Formoza's aren't directional, they are only marked "outside". You can rotate them.
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    Jun 2010
    Las Vegas
    Yes, they are asymmetrical and it is easy to rotate so I do when I’ve got the bike jacked up.
    Blueknight Mike I don’t understand what you’re saying. I never bothered rotating the Kendas as I couldn’t get rid of them quickly enough
    2010 RT- 622
