Results 1 to 25 of 27
    Active Member bcraig's Avatar
    Grove City, OH USA
    Default My solution for larger top case with passenger seat
    Bracket is made from 1.5"x1.5"x1/8" aluminum and attached to the bottom of the MAX Mount utilizing the existing 4 unused attachment points. The Top Case is this: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    IMG_0246.jpg, IMG_0245.jpg, IMG_0241.jpg,
    May 2018
    MN
    Oh wow what a great job thank you for sharing!
    Mar 2019
    GTA, Canada
    Brain dead simple... thanks for sharing .
    Any pics with it sitting outside? Would like to see how it looks with that case hanging so far behind... hard to see in these pictures.
    Side-view please .
    Grove City, OH USA
    Quote Originally Posted by mrNewt View Post
    Side-view please .
    Rainy day today, but here is side view.
    Mar 2019
    GTA, Canada
    Thanks! - Looks pretty good.
    I might steal your idea
    Grove City, OH USA
    One thing I'm monitoring is how close the bracket comes to the fender with a passenger.
    Mar 2019
    GTA, Canada
    Good call on that!
    Kansas
    Great job, looks fantastic. Did you make the washers or buy something?
    Central NJ
    How is it with case loaded and passenger ? Does it sag down much?
    What length did you make the alum angle?
    Grove City, OH USA
    Quote Originally Posted by KC61 View Post
    Just washers I had.
    Grove City, OH USA
    Quote Originally Posted by greckman View Post
    1. With just helmets and a jacket in the case there is no sagging.
    2. Haven't had a passenger yet.
    3. Brackets are 22.5 inches long.
    Grove City, OH USA
    Pictures of bracket with me on it and off it.
    Very Active Member Rogue Hawk's Avatar
    Apr 2015
    Chicago
    What top cases will it work with? Is it universal?
    2019 Rally , Black
    Grove City, OH USA
    Quote Originally Posted by Rogue Hawk View Post
    Since it's home made it will work with what ever you make it for.
    Apr 2015
    Chicago
    Quote Originally Posted by bcraig View Post
    Could I contact you to make me one? I will pay you of course.
    2019 Rally , Black
    Grove City, OH USA
    To quote Robert Burns "The best-laid plans of mice and men often go awry". Here is a picture of the distance between the bracket and fender with me seated on the bike (130 lbs) and a neighbor (100 lbs). Much to close, so back to Home Depot to figure out something else.
    Grove City, OH USA
    I really wouldn't be comfortable making a bracket for someone else. Sorry.
    In any case the current bracket isn't going to work out. See my latest post with picture.
    Nov 2018
    N.E. Ohio
    You could put a stiffer rear spring and or stiffer adj. shock. cueman
    Dec 2018
    NY
    You might want to try box tubing. Might be able to go with a smaller diameter
    Current: 2022 CAN AM F3S SS. Manta Green, Route 129 windscreen.
    Previous:CAN AM Ryker Rally. Intense black, side case , comfort drivers seat, comfort passenger seat with back r test, wind screen, LED auxiliary lighting.
    2022 F3S, special series , Manta Green
    Grove City, OH USA
    Quote Originally Posted by Jsmith8695 View Post
    I was looking at that at Home Depot as well shelving hardware which is "[" shape, but a heat steel.
    Grove City, OH USA
    Quote Originally Posted by cueman View Post
    I'm considering that too. Hoping LaMonster Garage offers their rear rack soon.
    Central NJ
    McMaster-carr, aluminium tubing stock with ¼" wall thickness
    just a thought
    Apr 2015
    Chicago
    Well, okay. But I do admire your handy work.
    2019 Rally , Black
    Jul 2010
    Las Vegas, NV
    Wider. If the rack is wider than the fender, you gain more clearance. There should be a way to see where the shock bottoms out. Then build the rack above that. Just a thought. Great job. Joe
    Joe Meyer
    Kansas
    If you are using the stock spring 2 up that sag is waaaaay too much. Probably why Can An sells the 2 up spring.
