whats the part number? I can't make it out in the picture.
2008 SM5, F1 EvoIII slide, Hindle, Race Air Flow System, O2 Delete, Fuel Pressure Modfier, Powerbus System, BRP 6 Spoke, 12V power supply x2, 1" Handel Bar Riser, CompuStar Alarm System w/pager, Mono Seat Cover, Brake Caliper Trim, Trunk Liner, Outdoor Cover, Carbon Fiber SM5 Handelbar Inserts, Carbon Fiber Tank Knee Pads, TBR Juice Box.
i don't have the package right now but just get the one that says 1157.
look for that label. they are by the neon accessary aisle.
6 states down 42 states to go
I'm from canada an we aint gotta pepboys here. I was gonna look online, if they even ship here.
Alignment Specialist
it's sold at pepboys for 25 bucks.
only have them in red. i wish it was white than it would be brighter but it's brighter than stock.
bigger reason for led for me was not having to change them often thou.
i already had to change them 3 times so...
i don't know if you can tell but on first pic, right side is the led. in person led is brighter than stock bulbs.
i only have 40 miles on them but i am going to san diego today so i will report if any problem comes up.
finally, 5th times is the charm
last pic is... was my fiberglass speaker pod that was just ran over by a pick up i just did the body filler and was ready for little sanding than paint...
I have the NMN product for the taillight...I see the packaging (your pic) says you don't have to fiddle with the computer, but how do you know that light is really compatible with the Spyder? We know Evan tests his products a lot...
Bone Crusher
If you work to make money, you'll never be happy, as there's never enough money...if you work to take good care of people, the money will always be there....Sean O'Connell, 1999
PhotoShop Master
evan told me that you cannot change taillights without modifiing other stuff
THOSE WHO LIVE BY THE SWORD DIE BY THE SWORD... BUT...THOSE WHO MASTER THE SWORD SURVIVE BY THE SWORD....
Rev. J. Proctor
reverendproctor.com
HAPPY SPYDER OWNER
after 4 more hours of ryding, there is no sign of any problem.
supposedly, this led has a chip in it to prevent triggering sensors and seems it is working. all the other led i tried triggered spyder's sensor immediately.
Actually, for LED bulbs, the bulb color needs to match the lens. "White" LED's don't have the same amount of red wavelength as normal bulbs. You need maximum red production to get it through the red lens.
If you use white LED's, your lights will be much dimmer once the red lens is replaced.
John Wells
Hollidaysburg, PA
AKA1004, please keep us posted. If you continue to not have any problems with these LED replacements, that's terrific news! Are they made for the other Spyder lights too?
Enjoying now: 2015 Spyder F3 SE6, 1970 Indian MM-5A, 1972 Suzuki RV90J Rover, 2017 Indian Chieftain (wife's)
Wish-I-had-kept-them: 2008 Spyder GS SE-5, 1967 Shelby GT500 w/Paxton supercharger, 1972 DeTomaso Pantera, 1991, 1992 & 2001 Acura NSX's, 2012 V-Star 950 Tourer, various 2-, 3- and 4-wheelers
spyder does not seem to care about other lights
i have replaced front markers on the fenders with white led and that was not a problem
kool
that does explain why white led that i have tried before in the taillight lens was dimmer than stock bulb(which triggered the sensors).
Obviously it's compatable if he put it in and it's working. Thanks for finding this ----- will be buying some this weekend! All that was needed was an electronic circuit to draw the proper amount to fool the Spyder computer. Most new cars will just give you a break light alert, or flash, etc. BRP should have done the same on the Spyder - a warning about a burnt out bulb - not causing the bike to go into limp mode---
Mod Maniac
...i have replaced front markers on the fenders with white led and that was not a problem
Just a side note... that circuit is not monitored.
ata = allergic to asphalt
My mods: https://www.spyderlovers.com/forums/...ead.php?t=5753
There are two kinds of people: (1) those who can read, reason and apply the experiences of others; and (2) those who just have to pee on the electric fence. ataDude, 2009
My Spyder:
LEDs
www.LEDlight.com has all kinds of super flux bulbs in all colors.
Prices range from 7.99 for white pucks to 27.99 for the superflux super bright 1156, 1157 and other types of bases including the wedges in GL1800s.
Ken krb1945 "Happy Owner"
USN DAV 100% 'er
Proud grandfather of a former United States Marine
1 2008 SM5 PE 548
1 2008 SM5, 1 2009 SE5
2008 GL1800
another 3 hours of ryding and no problem yesterday
The Superbright Luxeon 3 Watt is very bright, maybe 2x stock. The Luxeon 5W are absolutely stunning! I've used the 3W in bikes, not tried it in the Spyder yet.
John Wells
Hollidaysburg, PA
no problem after another day of ryde
i think it's safe to say this one is a keeper.
Hey aka, can you come up with a part number (do you still have the packaging), or should I just go and look at my local Pep Boys?
'08 SE5 #123 - Red - F1 Slider - BRP Comfort Seat - Spyder City 3" Riser
Please note that the package says "not approved for on-road use".
Went to local Pep-boys and that is what I read.......
Are they two stage? That is do they work as driving and brake lights? When you press the brake do they get brighter yet?
yes they are two filaments and will work as running light and brake lights.
yeap. and also my hid, leo vince muffler, race air flow system and probably my anti sway bar are not approved for street use. hindles too.
