whats the part number? I can't make it out in the picture.
2008 SM5, F1 EvoIII slide, Hindle, Race Air Flow System, O2 Delete, Fuel Pressure Modfier, Powerbus System, BRP 6 Spoke, 12V power supply x2, 1" Handel Bar Riser, CompuStar Alarm System w/pager, Mono Seat Cover, Brake Caliper Trim, Trunk Liner, Outdoor Cover, Carbon Fiber SM5 Handelbar Inserts, Carbon Fiber Tank Knee Pads, TBR Juice Box.
i don't have the package right now but just get the one that says 1157.
look for that label. they are by the neon accessary aisle.
6 states down 42 states to go
I'm from canada an we aint gotta pepboys here. I was gonna look online, if they even ship here.
Alignment Specialist
it's sold at pepboys for 25 bucks.
only have them in red. i wish it was white than it would be brighter but it's brighter than stock.
bigger reason for led for me was not having to change them often thou.
i already had to change them 3 times so...
i don't know if you can tell but on first pic, right side is the led. in person led is brighter than stock bulbs.
i only have 40 miles on them but i am going to san diego today so i will report if any problem comes up.
finally, 5th times is the charm
last pic is... was my fiberglass speaker pod that was just ran over by a pick up i just did the body filler and was ready for little sanding than paint...
I have the NMN product for the taillight...I see the packaging (your pic) says you don't have to fiddle with the computer, but how do you know that light is really compatible with the Spyder? We know Evan tests his products a lot...
Bone Crusher
If you work to make money, you'll never be happy, as there's never enough money...if you work to take good care of people, the money will always be there....Sean O'Connell, 1999
PhotoShop Master
evan told me that you cannot change taillights without modifiing other stuff
THOSE WHO LIVE BY THE SWORD DIE BY THE SWORD... BUT...THOSE WHO MASTER THE SWORD SURVIVE BY THE SWORD....
Rev. J. Proctor
reverendproctor.com
HAPPY SPYDER OWNER
after 4 more hours of ryding, there is no sign of any problem.
supposedly, this led has a chip in it to prevent triggering sensors and seems it is working. all the other led i tried triggered spyder's sensor immediately.
Actually, for LED bulbs, the bulb color needs to match the lens. "White" LED's don't have the same amount of red wavelength as normal bulbs. You need maximum red production to get it through the red lens.
If you use white LED's, your lights will be much dimmer once the red lens is replaced.
John Wells
Hollidaysburg, PA
AKA1004, please keep us posted. If you continue to not have any problems with these LED replacements, that's terrific news! Are they made for the other Spyder lights too?
Enjoying now: 2015 Spyder F3 SE6, 1970 Indian MM-5A, 1972 Suzuki RV90J Rover, 2017 Indian Chieftain (wife's)
Wish-I-had-kept-them: 2008 Spyder GS SE-5, 1967 Shelby GT500 w/Paxton supercharger, 1972 DeTomaso Pantera, 1991, 1992 & 2001 Acura NSX's, 2012 V-Star 950 Tourer, various 2-, 3- and 4-wheelers
kool
that does explain why white led that i have tried before in the taillight lens was dimmer than stock bulb(which triggered the sensors).
Obviously it's compatable if he put it in and it's working. Thanks for finding this ----- will be buying some this weekend! All that was needed was an electronic circuit to draw the proper amount to fool the Spyder computer. Most new cars will just give you a break light alert, or flash, etc. BRP should have done the same on the Spyder - a warning about a burnt out bulb - not causing the bike to go into limp mode---
OK, after I saw your report I went on Amazon last week and ordered a pair (LI-1157RCZ), "only 1 in stock." Put them in this morning, took a 50-mile trip through stop-n-go, and they worked beautifully. This so far is the only LED bulb available with built-in circuitry that will work with the Spyder. Any ordinary LED will trip the computer and set up the "limp mode" reading.
I have the Sport rack and it took a while to install; loosened the rack, removed both rear side panels and under panel, and removed one screw on each brake light assembly. I wiggled each assembly down enough to reach in, turn each bulb socket counter-clockwise and pull the socket out. Removed each bulb, replaced with led and put everything together again. (It helped that I have small hands; otherwise the whole rack would have had to come off.)
I am planning a long trip and did not want to worry about replacing a bulb on the road. When NMN "(ESI)" has the Givi bag lights available, I will order and install those as well, and that will give me lots of brake light !!
Will someone clarify. Are these $25 each or $25 a pair?
On Amazon they are $30. a pair.
it is what it is.
a great buy at $25 a PAIR.
it may or may not be a best solution depending on your needs vs. dollars.
works with spyder without any problem and brighter than stock.
I'm going to give them a shot too as sending in my parts, etc. just won't work. I'm also wanting to buy the GIVI bag lights from NMN - as soon as they are listed on their website.
Fire,
Why doesn't sending your lights in work? It only took a few days...was a very simple process...the lights are bright as heck and, of course, work fine...
Send on a Monday, you'll have back by Wed. or Thursday, unless you live in an extreme location.
Bone Crusher
Two questions, one easy.
1. Do these Pilot LEDs flash initially when brakes are applied and then go into steady mode?
2. Any thoughts on why they are not DOT approved? Made in China and not submitted for DOT review? Do they lose some brightness if not viewed directly from behind like some LEDs? Components don't meet DOT stds? ???. Checking local Auto Zone, Advance Auto, etc, but looks like Pep Boys may be only oulet in Michigan.
Registered User
Some companies don't want to spend the BIG $$$ to get the full DOT testing done on their products to sure they meet DOT requirements.
Without the testing being done they can't be sure the products are DOT compliant and are sure they meet the grade?
So, although anybody can say their product is DOT compliant, the fines are HUGE if you say they are, and testing shows in fact they are not DOT compliant after you said they were.
It may not seem like DOT testing should be important, that is right up to the point there is an accident! Then the Lawyers all seem to think IT IS I BIG DEAL for sure.
MM
[URL="http://www.esicycleproducts.com/"]
1. no flashing
2. i am guessing no money to get it dot certified for when it's retailed at 25 bucks led itself is working very well and these have wider dispersion than others i've seen and yes pepboys are the only ones that have them for now and they just got these in themselves.
Fire,
Right now Spyder is my only form of transportation. Other vehicle was taken out by a deer. Maybe come winter time----- but I won't give up riding my Spyder for a few days very easily at all.
These pep-boys units are NOT DOT certified - says so right on the package - for off-road use only. My guess is they are cheap--- but then again what should we expect for $25 ???
I would much prefer a unit that can just plug in where the stock bulbs go, so for $25 I may give these a shot.
Break light change, OMG!
St'09
I picked up 2 LED tail lights today from my local Lordco store. Part # is HIL-1157R. List cost is about $20.00/ea. Any Napa or auto parts store should be able to source these.
Cheers
Bruce
