Results 1 to 13 of 13
    Active Member bcraig's Avatar
    Apr 2019
    Grove City, OH USA
    Default Sport handlebar install on the Ryker
    Installed the sport handlebars today on my Ryker. They have about an inch less reach/pullback. The problem is they are a gloss black (shows scuffs) and about 1.5 inches longer. Being longer isn't a bad thing, but they located the keyed holes for the hand controls the same distance from center as the stock handlebars. As you can see in the picture that leaves a .75 inch space between the grips and the bar end mirrors.
    Nov 2018
    N.E. Ohio
    I like the look of the sport bars and the wider length but, I think I would drill the control pin holes to make the mirror mounts fit like the stock mounts. That way you get the full advantage of the wider bars. cueman
    Apr 2019
    Grove City, OH USA
    Quote Originally Posted by cueman View Post
    That's the plan. Tomorrow may be a rainy day so time to drill. I like the looks of the sport bar better than stock too. Also, more space for accessories without having to deal with bends in the bar.
    Nov 2018
    N.E. Ohio
    Please post an updated pic. Also, knowing what you found out, a person could buy a regular bar they like and drill their own holes and probably save a few dollars. cueman
    Default Let us see....
    Looks like you found the solution... make sure you update the picture so we can see your handy work...Only other solution would be to cut the ends off and have the mirrors flush again...
    ​2012 RS sm5
    Apr 2019
    Ft Pierce/Lk Placid
    For which sport?
    They look like regular ones. What's the difference?
    Apr 2019
    Grove City, OH USA
    After drilling new index holes and moving controls. Picked up a 7/8 inch handlebar from Iron Pony to try your suggestion.
    Active Member Micnice10's Avatar
    Jan 2019
    Rochester, MA
    Sweeet!
    Nov 2018
    N.E. Ohio
    Beautiful job, nice customizing. How do they feel? cueman
    Apr 2019
    Grove City, OH USA
    They feel good. May be my imagination, but feels like I have more control and less jerking. The reduced reach feels a lot better too.
    Mar 2019
    FL
    I've never changed handlebars so I have no idea what I'm talking about... how is it to remove/replace the throttle side?
    Apr 2019
    Grove City, OH USA
    Quote Originally Posted by kmonroe99 View Post
    I can only speak to issues I had with the install of the Sports handlebar, which I explained in this thread. Removing the controls aren't difficult, but as I explained you will need to drill new index holes for the controls, as explained above. Removing the left grip was the most difficult, but wasn't that difficult. Use air compressor to force air under the grip while pulling it off.
    Approach the project methodically and use common since. What I mean is walk through each step that you are going to take and consider what that step will do or affect the next step. For example: you don't unbolt the handlebars before your remove the grips and controls. It doesn't make any since to do it that way.
    If wrenching on your bike is beyond your comfort level then pay to have it done. When wrenching on your bike, you are going to make mistakes and you learn from them.
    Feb 2019
    England
    Hi bcraig it's a gap probably for hand guards? Regards Nico 75
