Sena Wifi Docking Station
Just received my sena wifi docking station and try to set it up. All did not go well when I got to wifi portion of set up it would not recognize my home neck work this is a I phone problem. Sena said they are working on a fix, but wright now you need a android phone to complet the set up. Will update when they have a fix.
BAJARON SWAY BAR PLUS LINKS
BAJARON SPACER
ULTIMATE SEAT WITH GAS DOOR
JT SHELF BAR
SPYDERFLAP
BUMPSKID
XM RADIO
POWER OUTLET
LAMONSTER CUP HOLDER
2015 RT LIMITED
PIN STRIPPING BY MACK THE KNIFE
RIVCO FLAG HOLDER
SENA SM10 BLUE TOOTH
LAMONSTER FBB HIGHWAY BRACKET WING BOARD BLK
BPR TRAILER HITCH
KRADELLOCK FOR THE GPS
BIG BRAKE PEDAL BY TRICLED
I don't understand what you are talking about. What is the model name of this 'docking station'?
2014 RTL Platinum
the wifi docking station is on the sena web sight , it recharges your sena 30k and 20 evo plus will do the firmware update
BAJARON SPACER
JT SHELF BAR
SPYDERFLAP
BUMPSKID
XM RADIO
POWER OUTLET
2015 RT LIMITED
RIVCO FLAG HOLDER
BPR TRAILER HITCH
I didn't know about it. http://www.buysena.com/WiFi-Docking-Station.html
Now I'm trying to understand how your home wifi network is related to your smartphone
2014 RTL Platinum
you need your home wifi for the docking station to get on the internet so it can due the updates
BAJARON SPACER
JT SHELF BAR
SPYDERFLAP
BUMPSKID
XM RADIO
POWER OUTLET
2015 RT LIMITED
RIVCO FLAG HOLDER
BPR TRAILER HITCH
If you don't have a computer or laptop then you need this docking station. Some headsets update vie the bluetooth connection to the phone like my Uclear. But still have to update the Sena with a cable and laptop.
I wouldn’t worry about it. Updates are only once or twice a year at tops. I have never updated mine in 3 years. Simply update it on the computer and use the docking for charging. I use my sena evo 20’s every day and play music everyday through them so the mic is open on the way to work. I maybe recharge mine once a month at tops. Why do you need it charged so often? If you’re on a trip away from home, take the cords and plug it into the wall or take your charger unit but you shouldn’t be needing it that often. If power is your concern get a portable battery jumpstart pod and plug your pods into it with the USB cable supplied. It will charge then in 2 hours if completely dead.
That I understand.
2014 RTL Platinum
Yes, I understand that. What has that got to do with your phone?
Is it that you are using your phone as a hotspot to connect your other devices to the internet?
I think of a home wifi as one that uses a modem/router for a hard wire connection to the internet. Very different from using a cellular hotspot.
2014 RTL Platinum
The dock uses an app on your phone to do the wifi setup.
Ah, that explains it. Thanks.
2014 RTL Platinum
