Results 1 to 14 of 14
    Central NJ
    Default Extension on max mount
    Has anyone added an extension to the max mount to put a bag behind passenger?
    Jan 2009
    austria
    I did - my girl wanted more space for her on our tours .. simple aluminium plate formed like the Mount-max - 12" longer ..
    Central NJ
    Quote Originally Posted by chris56 View Post
    how did you secure it to the existing max mount?
    any detailed pictures of how mounted?
    I have the comfort seats, both driver and passenger with backrest, do you think it would still work?
    thanks
    Jan 2009
    austria
    Quote Originally Posted by greckman View Post
    thanks
    its 4mm strong so maybe its possible if you cut out the wholes for the passenger seat - I use the original footrests for the costumer and made a new seat-cushion - the complete plate is removeable (including the seat - there is no cange on the driver seat (I use now also the comfort one )
    4 screas to fix it on the max-mount .. very simple
    Active Member bcraig's Avatar
    Grove City, OH USA
    How does the passenger pad attach?
    Jan 2009
    austria
    https://www.sattlerei-wakolbinger.at/motorradsattel/
    made from a professional company - together with a new "skin" for the backrest .. 250,-USD
    Feb 2019
    England
    Hi greckman what I've done is buy a givi tank lock ring ( usually fit on solo bike tanks) made alloy plate not to thick so it will go under pillion seat and drilled max mount 2 holes plate extends past hand holds just enough to fit a givi bag on , bag clicks on / off and can take any givi bag you choose cut plate the same shape as givi ring to make it look professional job done. Regards Nico 75
    Central NJ
    Quote Originally Posted by Nico75 View Post
    could you post pics of what you did?
    sounds like great idea
    thanks
    GRE
    Durham,Maine
    She must sit way over your head?
    2012 RTL , Pearl
    Central NJ
    how thick alum plate did you use?
    Durham,Maine
    Look at the picture! See where the bottom of his bucket is compared to her muff pad!!!
    2012 RTL , Pearl
    Sep 2019
    New Jersey
    I am in process of making my own max mount extension. Hopefully it will get done by the end of this week so I can post pictures. What I am making is very similar to Nico 75 post.
    Jan 2009
    austria
    ist 4mm .. and this is the "deepest" Position for the costumer ..
    Sep 2019
    New Jersey
    Here is my home made extension.
