Results 1 to 17 of 17
    Active Member JS3535's Avatar
    Sep 2017
    Clovis, CA
    Default F3T or L air suspension vs Elka
    What is better? Has anyone replaced the rear air shock with an Elka or added the air shock? Just wondering what has a more comfortable ride. Thanks
    2015 F3S-T , Black Black & Black
    Nov 2012
    North Las Vegas, NV
    The shock is separate from the air bag. Ride depends on the spring and damping control. There is a new vendor here that sells shocks.
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    Sep 2017
    Clovis, CA
    I thought it was all one assembly. So does the air bag make a difference in ride quality? Or is it just there to take weight off the shock?
    Aug 2016
    Pembroke, Massachusetts
    Quote Originally Posted by JS3535 View Post
    It is to adjust ride height.
    Bob
    Jun 2016
    Harrington, Australia
    What Bob said, JS. You can swap out your stock shock for any of the aftermarkets like Elka, Wilbers etc without going anywhere near the air ride bag........as an aside, I called it an air bag on one of the Facebook forums, and was swamped with people saying they didn’t get an air bag on their Spyder, even though the thread was about suspension. They all immediately thought of a crash airbag like comes on the Goldwing
    Pete
    2021 RT Limited
    HeliBars Handlebars
    Kenda Kanine rear.
    Sep 2020
    Montreal, Canada
    Default Help
    Pete
    I just brought my 2021 F3-T home last night. I spent half the night checking on it in the garage cause I’m in love with it. After noticing that it was extra mushy, and ending up on this fine forum, I found my way to the valve under the passenger seat. Wouldn’t you know it— zero PSI. The people at the dealership are a gang of bozos (for many reasons).
    Can you please tell me what Can Am recommends as a psi? I’m reading 15 40 even 60.
    Thank-You.
    Ted
    Active Member Michaelscs's Avatar
    Sep 2015
    Cold Spring, MN
    Quote Originally Posted by RNBOB View Post
    Bob
    I would agree, but it also affects the ride. It defiantly makes a difference in ride for me. I have 65# in when my wife rides with me and the ride is perfect. If I leave the 65# in when I'm by myself the ride is very firm. Usually have about 35 or 40# for great ride and handling by myself.
    2020 RT Limited , Petrol Blue
    Sep 2015
    Cold Spring, MN
    Quote Originally Posted by Theodore View Post
    Thank-You.
    Ted
    Please read your manual. Lots of important info there, including recommended PSI. There's also a label near the fill valve I believe.
    Sep 2020
    Montreal, Canada
    Thank-You Michael. Couldn't seem to locate that particular topic upon glancing last night but I'll read it inside out when I get home. (FYI-- no sticker anywhere near the valve on the 2021)
    Sep 2015
    Cold Spring, MN
    Your right about the sticker. I just went and looked at mine and it the sticker is on the bottom of the passenger seat. I knew it was there somewhere.
    Jun 2016
    Thank-You.
    Ted
    Wow.......it’s great to know that the manual set option is still available on the 2021 F3 T, Ted. I MUCH prefer that to the auto adjust option..... and you certainly aren’t the first to leave a dealer with zero in the air bag... it’s an all too common occurrence.
    .....and just by way of info, as you now know where your sticker is, I am running my airbag at around 65-70psi for my 310lb frame.
    Pete
    2021 RT Limited
    HeliBars Handlebars
    Kenda Kanine rear.
    Sep 2020
    Montreal, Canada
    Quote Originally Posted by Michaelscs View Post
    Found that exact chart in my owner’s manual. I’m about 175 lbs and I often ride with my wife or kids (all really light) so I set up at 40psi :-)
    Sep 2020
    Montreal, Canada
    Pete
    Beautiful !! And thanks Pete. It’s my first bike of any kind and you guys here on this forum are awesome. I’m glad I found it.... and you all. :-)
    Feb 2018
    NorEastern, Washington
    Thank-You.
    Ted
    Ted...
    I have played with the psi and like 15psi for one up. For me, it lowers the center of gravity and helps my F3T hug the road better than any higher setting. I run up to 60psi or more if I have 2 up and perhaps other weight.
    Regards,
    Don
    2017 F3T , Triple Black
    Jun 2016
    Quote Originally Posted by dondje View Post
    Ted...
    Regards,
    Don
    Yeah, that is far and away the best option if you have the patience, Don. Everyone’s thresholds and gut feelings are different. You HAVE to find what suits you personally
    Pete
    2021 RT Limited
    HeliBars Handlebars
    Kenda Kanine rear.
    Jun 2011
    Near Lexington, NC
    At 175lbs, one up, I find 25Lb works for me.
    Two Wheelers from 1963-2011
    Three Wheelers:
    2011 RT(Red)
    2014 RT(white)
    2016 F3T(red)
    2022 RT current ride(silver)
    __________________
    2016 Slingshot
    2018 Vanderhall
    2019 Slingshot
    Sep 2017
    Durham,Maine
    Quote Originally Posted by ulflyer View Post
    Everybody's pucker factors different!!
    2012 RTL , Pearl
