Results 1 to 10 of 10
    Apr 2018
    Ohio
    Default GPS / Navigation Question 2016 F3T
    Maybe a dumb question, but here it goes anyway: So I notice when scrolling through the inputs on my 2016 F3T there is a navigation screen. Is there some sort of "out-of-sight" plug in where navigation will show/play through the audio system on this byke?
    TIA
    2016 F3T , Red
    Jul 2011
    Mitchell, Ontario, Canada
    Not a dumb question.
    Yes you can connect a GPS to a 2016 F3T. I would have to look it up for the location for your model for sure, but I would guess the connectors will be on the left side. Under the body work, under the seat.
    Apr 2018
    Ohio
    What exactly do you connect? And then it just displays on the screen that is built into the bike?
    2016 F3T , Red
    Jul 2011
    It is designed for the Garmin Zumo 590 motorcycle GPS. If you by the GPS kit from BRP. It has the hardware to mount the GPS to the center of the handle bars. The wiring harness from the mount is connected to 12V power and inputs audio to the radio. The map is displayed on the GPS. The audio comes from the Spyder speakers. The GPS can be used as a mp3 player. That is what the screen, that you saw is for. But if you are listening to FM radio for example. It will mute the FM while the GPS give out turn directions.
    Jul 2011
    See the item labeled GPS2
    Jun 2018
    Melissa, TX
    The Garmin Zumo will also bluetooth to your headset, which is much easier to understand going down the highway
    If you have a Zumo 590 you can purchase a mini-SD card that you can load with music and insert in the GPS. You open the back of the GPS, lift the battery and you will expose the slot for the SD card. If playing the MP3 player in the Zumo it will mute the music for turn-by-turn directions and school zone warnings from the GPS. Garmin OEM Product Support, 855-607-2536, can help too.
    Apr 2018
    Ohio
    Thanks everyone ... I've been thinking about possibly the 396 LMT-S. I assume it works much the same way. Really I just want to have the ability to Bluetooth directions into my helmet with least cost possible and without mounting my phone on the handlebars. I have ZERO interest in getting phone calls or text or FB message notifications while riding. Hoping to maybe pick up a good used unit one day. I use Amazon Prime music for my tunes (on an old iPhone plugged into the USB in the glove compartment) so I don't think I can save the music to an SD card.
    2016 F3T , Red
    Mar 2017
    >CLICK ME< then scroll down to GPS. There is a wealth of information there on the 2016 F3T and how to hook up a Garmin Nüvi with audio. You can pick up a Nüvi 56lm for just about $60 on eBay and make it work with the GPS audio in.
    Apr 2018
    Ohio
    Let me ask this odd question. I have an old iPhone (no cellular service) that I use as my music player for Amazon Music I have downloaded for offline use. I plug the iPhone into the USB in the glove compartment. If I download Rever app with maps for offline use and plug the 3.5 jack into the iPhone as well. Will the GPS directions overide the music when necessary?
    2016 F3T , Red
Tags for this Thread
