Results 1 to 10 of 10
    Active Member ladygadget's Avatar
    Jan 2019
    California Delta
    Default Baja Ron Anti-Sway Bar
    Hi everyone!
    Does anyone know of a shop in the San Francisco east bay area that can install a Baja Ron bar?
    I bought one but have no way to lift my Spyder to install it.
    I'm in Antioch.
    Any ideas or recommendations welcome.
    Thanks !!
    Default Little checking.....
    Not familiar with your area but you can check with the local dealers in your neck of the woods as many will install them. Otherwise check with some other shops showing them the instructions from Ron which are easy to follow and clear. Maybe check with the spyders to the rescue crew some do mechanical work
    ​2012 RS sm5
    Jun 2010
    Las Vegas
    Hi, I sent you a Private Message with info about an installer in Tracy, CA
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Dec 2018
    Minneapolis
    Where do you get a Baja Ron Sway Bar? What color are they and how much?
    Very Active Member hypurone's Avatar
    Jun 2016
    NorCal - Northbay
    Quote Originally Posted by SmoothE View Post
    Check the vendors list here. A lot of them sell his stuff. roughly 288.00 with new end links (highly recommended)
    Chuck
    Aug 2007
    Greeneville, TN
    All of the bars are powder coated black. Since you really can't see them when installed it makes little difference.
    Depending on the model. The Heim Joint Links are more or less visible. They come in Red and Silver from me and other vendors. Black from Lamonster (though he may be out of them right now because I had run out of them).
    Active Member SmoovOpRatoR's Avatar
    Nov 2015
    West Coast, Canada
    I saw a post not too long ago about someone who rented aluminum ramps from Homedepot, put the ramps on the back of a pick up truck and then drove their spyder up the ramps and this provided enough lift to get the old bar out and new bar in. As long as you chock the rear tire I think it would be a safe way of doing it.
    Apr 2019
    Florida
    2019 F3 Limited , Big Bike Parts full size pedal Black Metallic
    Linden, CA
    Give me a call I am east of you near Stockton
    209-887-3283
    Dave
    Quote Originally Posted by ladygadget View Post
    Hi everyone!
    I'm in Antioch.
    Thanks !!
    Jul 2014
    Pennsylvania
    We used an engine lift. Straps on a arms close to the tires . Worked out great. Only lifted long enough to switch out the bar itself
Tags for this Thread
