Results 1 to 6 of 6
    Member spyderman504's Avatar
    Aug 2012
    Louisiana
    Default 2009 canam spyder se5 gs brake failure code
    Hello all I have a 09 spyder gs se5 it’s been 6 months since I started it up but it’s alwqys on a battery tender also I put the gas treatment recommended for the spyder if the bike sits up it started up fine yesterday now today it won’t crank over battery is good brake fluid is full the code it shows vss fault and abs fault I took a short video to show you guys please help thanks and happy Easter.
    Jun 2015
    NYC
    change your spark plug mine did same thing she running now
    Aug 2012
    Louisiana
    Ok thanks buddy do you have a video I can watch or send me so I can do that
    Default Curious...🤔
    To be clear the engine now does not even turn over....? If so start with the battery and all its connections. Don't know the age of the battery but may be done and only working on a surface charge. Try jumping with another battery or the car engine off. Multiple codes are a common cause from a dead or weak battery. If it is turning over but will not fire up try the TWO throttle wide open proceedure. Turn her on, hold the throttle wide open and crank the engine for 10 sec or so. Then try starting normal may take a couple tries.
    Brake codes can come from low fluids, sticking brake light switch, brakeligh bulbs, brake pads you see a lot mentioned here. Start with the fluid and pedal switch.
    Gene and Ilana De Laney
    Mt. Helix, California
    ​2012 RS sm5
    Aug 2012
    Louisiana
    Thanks for your help chubaca
    Aug 2012
    Louisiana
    Up date to all it was the battery somehow the battery tender wasn’t giving it a full charge so I charged the battery overnight and now runs like a champ thanks to all for your help God bless.
