Results 1 to 11 of 11
    May 2017
    Mesa, Arid-Zone-A
    Default Temperature read out error
    Is there any way to correct the temperature readout setting? Mine indicates about 5-7 degrees higher than actual temperatures. I guess I could just look at it and subtract 5 degrees but it would be nice if it told me the truth..... Jim
    Semper Fi
    I also have a 14 RT …. and it isn't accurate either ….. the sensor isn't in a great location for accuracy ….. Mike
    Dec 2013
    That sensor isn't necessarily telling you what the ambient temp is, like a weather report might - due to the sensor location, it's more aimed at telling you what the 'under-tupperware' temp is, ie, the temp of the air being delivered to the engine.... When that hits 100° or higher if you've just made a short stop or been idling along in slow moving traffic, don't be surprised if you see a 'high temp warning' or even a 'limp home mode' due to the over-heating; but it'll often go away once the fans start up or you begin to get a bit of air-flow thru the tupperware!
    2013 RT Ltd Pearl White
    Ryde More, Worry Less!
    Active Member Valkrocket's Avatar
    May 2018
    Murrells Inlet, SC
    BRP has made Zero improvements on their sensors over the years. My 2018 has readings between 5 and 10 degrees above the actual temp. every ride. And let's not talk about the horrible readings when stopped for any amount of time. Why bother putting a gauge on the Spyder if it's going to give you inaccurate readings. These vehicles aren't cheap, but some of their designs sure are.
    GLIDE-ON>>>>>>>>>>>>>>
    "Blue Belle" 2021 RTL Chrome in Petrol Blue
    2021 RTL Chrome , Petrol Blue
    Very Active Member bluewoo's Avatar
    Sep 2018
    greensburg,pa
    Where is it located on a RT?
    Never mind I found it.
    2021 RT LTD Petrol Blue DARK delivered 9/22/20
    New Engine @ 500 miles 4/8/21 - 5/21 due to oil leak in block
    https://www.spyderlovers.com/forums/...400-miles-HELP
    2018 RT-L , Blue
    Active Member kbwitt's Avatar
    Jun 2015
    AZ
    What really pissed me off is on a $30,000 vehicle they can not put a clock that stays accurate. Please a $8.00 watch at Wal-Mart keeps accurate time.
    Default See post #3
    Pete explains it for you. The location is usually low and close to the air intake picking up the heat off the asphalt as well. The clock is a whole different story. As for the true temp you have it on your phone or get a stick on and your good. You have engine temp which is the one you should worry about the other does give you a reference give or take those 5-10 degrees...
    ​2012 RS sm5
    SoFlo
    Pretty certain you will find the engine has an ambient temp and pressure sensor. That is the reference for the engine intake air. Not sure if the computer compares both, but the engine sure runs better when the temps are OAT are lower.
    My 14 is about two degrees generous. I live with it.
    Nov 2012
    Pueblo Colorado
    Quote Originally Posted by canamjhb View Post
    Jim - As you have correctly noticed, the display temp is right at 6-7 degrees high to the outside ambient temperature. The good news is it is quite accurate as we also see the 7 degree higher temps on our 15 RT and 16 F3T, so apparently the location and accuracy of the gauges carries from one Spyder to another... just have to subtract the 7 degrees to get the outside air temp (while moving down the road of course)
    07 Shadows, Aero, Spirit gone but not forgotten
    03 Harley Sportster, 07 RK moved on
    11 RT- 76,000 mi, 15 RT-S- 44,000 mi, traded for current 15 base RT and 16 F3T
    2015 RT , OEM Black Gloss
    Idaho
    It's a combination temperature and ambient air pressure sensor located at the top side of the right air tunnel in the front module. I cut a bigger hole in top of the tunnel for mine. That helped quite a bit. As it is air skims past the bottom part of the sensor and not over it. By cutting the hole bigger I got more air to circulate around the sensor. You don't want to do anything that will cause air to move too hard against the sensor because then it'll read ambient pressure higher than actual. (Maybe that's why my gas mileage seems to worse than everyone else!) It takes about 5 miles or so of driving before the temp sensor reads real air temp. And has been said, it is sensitive to being heated by sun shining on the frunk. Hot air from around the engine may move over it also when you are stopped.
    2014 Copper RTS
