Results 1 to 21 of 21
    Mar 2019
    Salt Lake City
    Default Ryker Mirror positioning
    Hey Everyone!
    I picked up my Ryker 900 yesterday, and have really loved riding it. I cruised through my neighborhood, on some main roads, and took it on the freeway (got it up to 90 MPH in Eco mode without trying too hard).
    My question for everyone is where have you been pointing your mirrors? I've found some good tips for mirrors mounted closer to the center, but since the stock mirrors are on the end of the handle bar, it's going to be different. Right now I've got the right mirror pointing mostly behind me with some visibility for the right lane. The left mirror is pointed more outward. I think I've got the up/down level set correctly. Let me know what you do, and what you find works best. Thanks!
    Jenko
    Very Active Member Tslepebull's Avatar
    Dec 2018
    East Texas
    I was surprised how good the Ryker bar end mirrors were. As far as an answer to your question I position the mirrors to see beside and behind the bike on both sides; far enough out that my elbows are usually not in the picture. I try to position the mirrors in such a way that if another vehicle is approaching on my quarter I can start to see the approaching vehicle in my peripheral vision (right or left) just as it is leaving the mirror image. I can still see vehicles behind be some distance back but only the medial side of tailgaters. It will feel odd at first like, your mirrors are pointed toward the bar ditch, but works very well for me.
    You still need to do a proper head check to change lanes (when you have the time) but this mirror position lets me know at a glance if there is an escape spot (right or left) when the situation in front of me degrades quickly.
    2019 Ryler Rally , Shock Yellow
    Nov 2012
    North Las Vegas, NV
    You can always get the Lamonster mirrors.http://www.lamonstergarage.com/can-a...ors-lamonster/
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    Active Member mikeyuberalles's Avatar
    Feb 2019
    Clearwater, FL
    I prefer the lamonster mirrors. I really didn't like how low the stock mirrors sit.
    Apr 2019
    Ft Pierce/Lk Placid
    Point the left mirror similar to the right, and everything will be hunky dory!
    Active Member MidlifeRyker's Avatar
    Mar 2019
    CO
    100% agree on the Lamonster mirrors. They make a world of difference.
    2019 900 ACE , Black
    Apr 2019
    California
    looks like this is the first upgrade I'll be doing. Lemonstar mirrors. Also found these, on spyder extras
    Mar 2019
    FL
    Quote Originally Posted by DirkDiggler View Post
    What kind of bar ends did you put on?
    Feb 2019
    Clearwater, FL
    I installed these.
    Apr 2019
    California
    on the web site spyder extras they have the bar ends for $48
    Apr 2019
    Ft Pierce/Lk Placid
    Quote Originally Posted by MidlifeRyker View Post
    But do they not buzz & are consequently not blurry like the factory mirrors? If not, that is the only I might get them. Not for "looks".
    Feb 2019
    England
    Hi all ref mirror position just sit on bike , feet on pegs , adjust mirrors so that you can see full view of traffic on near / off side when in comfortable seating position
    Dec 2018
    Peculiar, Missouri
    I have been thinking bout using the Ryker mirrors and adding the Lamonster mirrors also. I was considering using the Ryker mirrors set at my blind spot at 4 o'clock and 8 o'clock position From there I would use the Lamonster mirrors for behind out to the 4 to 8 o'clock position. The Ryker mirrors are limited in there sweep out to the side and might have to reverse the use of the mirrors.
    Very Active Member Markubis's Avatar
    Jan 2018
    NH
    Quote Originally Posted by graysonsway View Post
    I did the exact thing this past weekend. Got my LaMonster mirrors on and considered taking the originals off. Then I tried swiveling them down low, but in the end I had the originals back up on the top side of the handlebars with the LaMonsters also up top. With the two sets of mirrors close to each other above my grips I can now get multiple views with one glance.
    Apr 2019
    Florida
    I purchased the Lamonster mirrors but having a hard time finding a place to install them on the stock Ryker Rally handlebar. i can't seem to find a flat area to secure the mounts. Did anyone have to use a shim or spacer to to get the mounts tightened?
    Jan 2018
    NH
    I put mine just on the other side of the hand guards on my Rally.
    Feb 2019
    Clearwater, FL
    Quote Originally Posted by Markubis View Post
    Me too. I put them as close to the grips as possible.
    Very Active Member campermac's Avatar
    May 2015
    Etters PA
    I mounted my Lamonster Mirrors on my handle bar directly to the hand guard mount. I took the top hole of the mirror bracket and ovaled it out a bit and it matched up perfectly. They look like they are original equipment for the Ryker.
    2022 RT Limited , Silver w/ Black and Purple accents
    Jun 2019
    NY
    Hi, could you post a pic? I am getting these delivered today and didn’t realize they weren’t compatible with the Rally handguards.
    May 2015
    Etters PA
    these are the best I have for now. If you want more provide me your email address and I will email them to you
    Jun 2019
    NY
    Thanks so much! A couple of additional pics would be appreciated! My email is nicollejansson at yahoo dot com.
