Results 1 to 11 of 11
    Active Member SpyderCruiser's Avatar
    Nov 2014
    NJ
    Question Has anyone tried Hankook Ventus V4 ES H105 - Size: 175/55R15 Front Tires?
    Have a 2015 RTL was considering running these tires up front https://www.tirerack.com/tires/tires...omCompare1=yes
    Has anyone that installed these care to comment on them?
    2015 RTL , Red
    Very Active Member JKMSPYDER's Avatar
    Dec 2012
    Murphy, NC
    I had my dealer install Hankook's on the front of my F3-S after my Kendas wore out. I now have over 14,000 miles on them and am very pleased. Virtually no wear at all!
    2020 F3 Ltd
    Spyderpops Bumpskid
    Spyderpops Brake/Run/Turn Signal LED's
    Lamonster Garage LED Fog Lights and Headlights
    2013 ST-S retired 1/9/16 at 25,061 miles
    2015 F3S sold at 77,565 miles.
    2015 F3-S , BajaRon Plugs Can-Am Red
    Nov 2014
    NJ
    Quote Originally Posted by JKMSPYDER View Post
    Thanks for your reply.
    How is the grip and wet weather traction? And what PSI are you running?
    2015 RTL , Red
    Very Active Member campermac's Avatar
    May 2015
    Etters PA
    I have them on my 2015 RTL. Have not had them in the rain yet just put them on at the end of last year but as for dry roads a lot better than the OEM Kenda's
    2022 RT Limited , Silver w/ Black and Purple accents
    Apr 2017
    North Central Florida
    I like the tread pattern; looks like they put a lot of rubber on the road.
    What are you using on the rear ??
    Quote Originally Posted by Easy Rider View Post
    Looks only matter when choosing a Date ……… you can't tell squat by the tread design ( this does not matter with / for MUD tires ) …..jmho …. Mike
    Nov 2014
    NJ
    Going to install a Yokohama S Drive that already have on hand for the rear. We prefer direction tread tires, they squeeze the water out of the tread better then regular tires. The yoko and the hankook are directional tires.
    2015 RTL , Red
    Very Active Member SPYD3R's Avatar
    Apr 2011
    GREENVILLE, SC
    i mounted mine on April 11, 2016 and now have 24,000 miles of smiles on them and they still look great....
    they also handle far superior to the OEM KENDA's....
    i figure i still have no less than 30,000 miles of wear left on mine...
    keep your PSI up and you can't go wrong.... i set mine at 18PSI.....
    good luck, and ride safely....
    Dan P
    SPYD3R
    Click image for larger version.
    ID: 158030 Click image for larger version.
    ID: 158031 Click image for larger version.
    Apr 2017
    Quote Originally Posted by SPYD3R View Post
    Thanks Dan.
    (The pictures are not viewable.)
    Sep 2017
    Durham,Maine
    Never seen anything stir up the hive better than a TIRE or OIL question in my life!!!
    2012 RTL , Pearl
    It has become unstirred.
