Results 1 to 6 of 6
Thread: oil engine
    Active Member FlyBoy2121's Avatar
    Aug 2018
    Canada
    Default oil engine
    Hello everyone
    I know this subject is taboo
    What can of oil put in spyder RTL when your warranty is over, can we put full synthetic, or the BRP kit always.
    Tank You !!
    Flyboy2121
    2014 RT ltd , original original Cognac
    Apr 2017
    Wisconsin
    Use whatever brand and blend synthetic or semi synthetic oil you would like. Just make sure it meets the oil specs found in your owners manual. You could have done this while it was still under its warranty. OEM's can not force you to use their brand oil by law in USA (not sure in Canada where I see you are).
    Sep 2016
    Chillicothe, Oh.
    Rotella T6 and did it way before the warranty expired.
    2015 RT , Black
    Active Member ricford's Avatar
    Jun 2015
    Calhoun, La
    I bought my '14 RT new. First and all subsequent oil changes I have used Amersoil full synthetic. I think the BRP branded oil is Castrol. I think. I am pleased with the oil, I read a lengthy report on it which reported it to be top grade. And so far, no issues. I buy it by the case and take to shop to change.
    Jul 2014
    Mint Hill, NC
    Quote Originally Posted by JAS POWER View Post
    Use whatever brand and blend synthetic or semi synthetic oil you would like. Just make sure it meets the oil specs found in your owners manual...
    Second sentence is the most important one. In or out of warranty doesn't matter except if something goes wrong the repair costs will come out of your wallet if you don't use the specific API service code lubricant.
    otherwise be a vulgar brawl.
    Cognac 2014 RT-S
    Aug 2018
    Canada
    Hello everyone
    Currently my 2014 RTL is guaranteed until the month of May 2020, after the warranty period I will put Rotella T6, I know this oil well.
    Thank you all for your answers.
    FlyBoy2121
