Schrader valve
Hello out there, what is the maximum amount of air should be in the schrader valve when not sitting on the spyder. Thanks
2015 RT Limited
Read your operator's guide; it's in it.
Since the sticker next to the valve recommends that you not exceed 10 psi OVER the recommended chart and the pressure for 250 lb driver and 250 lb passenger is 85 PSI, I would say 95-100 psi....I usually try for 50 psi 1 up....
07 Shadows, Aero, Spirit gone but not forgotten
03 Harley Sportster, 07 RK moved on
11 RT- 76,000 mi, 15 RT-S- 44,000 mi, traded for current 15 base RT and 16 F3T
Since the RT Limited's all have an automatic system to keep the pressure adjusted, I don't believe that chart is in the owners manuals for those models.
AND....that valve is there mostly just for checking to see that the automatic system is working.
If you manually add or remove pressure, the system will go back to what it wants to be.
Indeed it is - at least for the 2014
AJ
2014 RT-S
Akrapovic Exhaust & Cat Bypass
Bajaron Sway Bar w/links / Sena SM-10/Garmin 660
Comfort Seat w Adjustable Backrest
Decals by Purple Harley / Magic Strobe
Kuryakyn Black Widow Pegs Rivco Highway Brackets
Rivco Trunk Mounted Double Flag Holder
FOBO / Spyder Cuff / XM Radio w MC Antenna
