Results 1 to 11 of 11
    Active Member Nuke's Avatar
    KNOXVILLE, TN
    Default Where is this junction? (Maybe a plug)
    Looks like I finally found the subforum I've been searching for. I'm going to be installing a brake flasher module that has a three wire hookup on my wife's 2019 F3-L. Basically, I need to cut the white brake signal wire and insert the flasher module, then ground it. No problems for me there... I've got that part down. The part I want to figure out is how to wire it in without cutting wires. This will require making a harness. To do so, I think I've tracked down a good place to make a harness for it, but I need to see it physically so I can see what plug I need to order. In the photo, the wiring diagram shows a junction labeled as JT OG 2 and JT WH 2. I've circled it in green. It's officially a "wire splice" but I'm assuming it's a plug. Does anyone know where this is? It is probably a 3 wire plug with a white, orange, and black wire in it, somewhere near the trunk. I tried following the main harness but it disappeared into the rear of the bike. Thanks for your help.
    Nuke
    2019 F3 Limited , Phoenix Orange Metallic
    Feb 2019
    Portland, Oregon
    I did that without the complexity of your route. I bought a flasher for less than $5 with free shipping from Banggood.com that has on 2 wires in and out. Yes, wires had to be cut, but I used Posi-Lock connectors for ease of installing and changing. I did just the brake light in the trunk,
    https://www.banggood.com/20W-LED-Bra...r_warehouse=CN
    Jul 2011
    Mitchell, Ontario, Canada
    A junction is just that. Wires are spliced together. No it is not a plug.
    Mar 2017
    Salisbury,NC
    for not cutting wires, I came across these last year. a "T" splice, that takes a blade to run new wire
    Bossier LoUiSiAna
    Quote Originally Posted by Woodaddict View Post
    yup these are quite handy when adding items when there is limited slack in wire to work with for a additional splice & even easier if the addition needs temporary removal (adjustments). No wire nuts, solder, or tape just google : spade T splice & can find what assorted value pack will do you best.
    Jul 2011
    How the heck is that going to work? Don't see how you can add a brake light flasher by just tapping into the brake light wire.
    Jul 2011
    If you do want to make a harness and leave the OE wiring intact. Just get yourself a male and female Delphi GT 150 16 pin connector. Wire it so everything passes through except the brake wire. Insert it at CIC1 or CIC2 depending on which wiring diagram you are looking at. At least this mistake is on the 2018 wiring diagram. This is how BRP inserts the trailer harness.
    Nov 2015
    Mickleton,nj
    Nuke,
    I installed the strobe light module from Lamonster, works great and it’s plug and play.
    http://www.lamonstergarage.com/can-a...ster-approved/
    Steve
    Sep 2014
    USA
    DelCity has great pricing on Delphi connectors. Just a FYI.
    KNOXVILLE, TN
    Quote Originally Posted by Stevew View Post
    Nuke,
    Steve
    Thanks for the suggestion, but I already bought the flasher from Custom Dynamics, and I want all the tail lights to flash, not just the top case. This is so that if I take the top case off, I still get the tail lights on the bags to flash.
    KNOXVILLE, TN
    This is probably what's going to wind up happening. Either this or I am going to just buy a Delphi 2-pin and cut and add it inline. Thanks for naming this big plug though, I wasn't sure who made it.
