Hyper-lites
I need some advice on how to access the hot brake-light wire so I can install some Hyper-lites. I know I can find my way into the wiring that runs along the bottom of the swing-arm, but I'd rather tie in into the back of the tail-light(s) itself. Problem is: I can't figure how to drop the tail-light assembly from its mount on my 900 Rally to get at the wire as far back toward the lights as possible. I'm probably missing something obvious, but I'll appreciate any available good advice. Thanks.
Hi animosh,
I want to add Hyperlites also and it would be much appreciated if you would tell how it went. Thanks.
CENTAUR
"IT'S BETTER TO BE SHOT OUT OF A CANNON THAN SQUEEZED OUT OF A TUBE"-Dr. HS Thompson
