Results 1 to 9 of 9
Thread: 2010 RS Toolkit
    Active Member WisconsinDavid's Avatar
    Sep 2018
    Beaver Dam WI
    Default 2010 RS Toolkit
    I can't find the toolkit for my 2nd hand spyder, 2010. I think that it was supposed to be located in the frunk. There is only a manual there. What is in the toolkit? I need a spanner to adjust the shocks. Will a universal spanner work (can be bought locally) or does the shock only take the BRP wrench that is like 20 bucks delivered? Thanks. Scavenger hunt time.
    Default Little checking.....
    The tool kit...if it is still there will be suspended on the left side of the trunk. I have found that you can change the setting of the shocks with no weight on them by turning the spring. But there are some adjustable spanner wrenches that will work if you have no tools...
    ​2012 RS sm5
    Sep 2018
    Beaver Dam WI
    Thanks. I can see the two prongs where the pouch must have been located. I have tools, but no spanner wrench. I just ordered one from amazon. I just was concerned that the shocks might need a propietary tool. Thanks for the update that when lifted and unloaded ... easy to turn and adjust. This board is a great resource! Thanks for sharing your knowledge.
    Jul 2011
    Mitchell, Ontario, Canada
    Here is what is in the tool kit from the factory. The shock wrench, item 4, is still available from BRP.
    2018 F3 LIMITED
    Jul 2016
    australia
    whats the funny thing next to the key ring with the shim checkers on it,far right last item.
    Jul 2011
    Tire pressure gauge.
    2018 F3 LIMITED
    Jul 2016
    australia
    ok thanks my mates is missing a lot from his including the tyre pressure gauge
    Very Active Member PistonBlown's Avatar
    Jan 2013
    Christchurch, New Zealand
    @Stu - Missing the tyre pressure gauge isn't a big issue, they're electronic and I'm sure they are just fitted with a random number generator. I could read the same tyre three times in succession had end up with 3 completely different readings:-) Ended up chucking mine for a standard pencil one, which works a lot better for rear anyway.
    Active Member Nobodyjj's Avatar
    Sep 2018
    Caledonia,Ontario,Canada
    You could make your own wrench with a piece of flat stock. There are adjustable ones you can get at any bearing supply house. SKF makes various sizes.
