Results 1 to 25 of 37
    Oct 2014
    Ohio
    Default Windshield preferences ??
    For a 2016 RT Limited, anyone have experience with windscreens different then the OEM ?? I am 5'10" wear a full face Shoei helmet... I constantly get a lot of wind noise and buffeting...raising the windshield does not help the problem, so I assume it is coming from the sides...
    Anyone who has had a similar experience and any recommendations will be appreciated.
    Mar 2015
    forrest above Reno, Nv
    Question To vent or not to vent???
    A vent in the shield will make a world of difference. Least expensive is to get a Goldwing vent for about $50 and cut the hole your self. Or spend $200 to $400 for an aftermarket shield ( with a vent of course ). Many here have done the replacement.
    Kaos
    2014 RTS , Circuit Yellow
    Do you ride with your faceshield fully closed? Fully open? Somewhere in-between"
    Sometimes, a small movement in the positioning of the shield can make a big difference in how the airflow plays with your head.
    Otherwise: put a vent in it!
    May 2013
    Apex, N.C.
    I have gone through quite a few options and now have the perfect set up. I started with the stock, and it worked for the first season.
    Then I wanted more protection in the winter so I ordered a +4 width.
    The following summer I wanted more air, so I cut 7" off my stock 25.5" heigth. This worked great for the summer
    This past spring, I decided it would be nice to tint the short shield. I tried the film, and it didn't work, so I purchased the spray on tint. It worked, but ran. I had to apply coat after coat to get it to look good. The result was great, but in the up position, I could not see very close in front of me.
    Finally I found a short but wide, vented shield. It is a +4.5" width, but 4" shorter than stock. This is the perfect year round shield.
    At full extension: do you look through it, or over the top?
    Active Member Cruising RT's Avatar
    Dec 2014
    United States
    Cool
    Do you know who manufactured your current windshield, model #? Any good source to purchase. Thanks for any help.
    Oct 2014
    Ohio
    I normally ride with the shield fully closed.... So a vent in the windshield will improve the situation?????
    Oct 2014
    Ohio
    What brand do you have with the +4 width?????
    Quote Originally Posted by biker01red View Post
    It's sort of a "Hit & Miss" thing...
    What it does; is change the airflow a little bit.
    Try opening the shield up just a notch, and see what happens.
    Putting a vent in your windshield will reduce the amount of buffeting, by smoothing out the airflow around it.
    Basically; it reduces the size of the "low pressure" area, that exists right behind the screen ( and in front of you)
    But raising your faceshield costs nothing, as a simple experiment!
    Oct 2014
    Ohio
    Ok, thanks for the info, I will give it a try......
    formerly pman2011 YIRYDE's Avatar
    Sep 2012
    Northern Virginia
    Is that the F4 sport wide tint/vent windshield that you have in your last picture?
    [B]
    2018 Intense Red F3T (See About Me under My Profile for mods)
    2010 Timeless Black RT-622 Trailer
    2014 Timeless Black RTS-SE6, 34,300 Miles, traded May 2019
    2011 Timeless Black RTS-SE5, 15,180 Miles, traded April 2014
    May 2013
    Apex, N.C.
    At full extension I look through it. I find that really nice for riding in the rain. I can just close the vents and keep riding. My wife is only 5'-2" and I am 6'-2", so we are both able to stay pretty dry as long as we are moving.
    May 2013
    Apex, N.C.
    The one with the +4 width and vent is a F4 shield. I do not know the part number, but I purchased it as an open box item on Ebay for around $250 shipped. There was a slight blemish on the edge in one spot, but you would not notice it unless I point it out. Although I love it, if you are wanting a normal heigth shield (25.5"), but just +4 wide, I suggest the cheaper one by show chrome. They are less than 1/2 the price and work better. The reason I say better is because they come with the vent holes at the bottom like the stock shield. The F4 without the vent does not have the stock vent holes. JMHO
    Oct 2014
    Ohio
    Ok, thanks for the info, I will go to their websites and check them out !!!!!
    Active Member Brian Kay's Avatar
    Kennesaw, GA (Atlanta Area)
    I'm rocking the Cal-sci stock height but wide and love it...very quiet when full up and enough air flow when down. I'm 6ft tall but have a 2xl shoei rf-1100 on the skull acting like a big sail lol.
    Brian Kay - Kennesaw, GA
    2014 RT-S SM6 Pearl White (KHAOS)
    TricLED 3rd and 4th Brake Lights - TricLED Turn Signals - TricLED Side Fender Lights - Airhawk R Seat Pad - Smoothspyder Belt Tensioner - JT's Dash Mount - JT's USB and 12v Power Unit - Stebel 139dB Multi Sound Horn - Lamonster NBV Highway Pegs - BRP Adjustable Wind Deflectors - Cal-Sci Stock Extra Wide Windshield - Baja Ron Sway Bar - WrapMySpyder 1330 Triple decals - Ultimate Tallboy Seat - BRP Sat Radio - ELKA Stage 2 Front Shocks
    Very Active Member irvin48's Avatar
    May 2016
    mt morris il
    Quote Originally Posted by Brian Kay View Post
    got a pic and price on it ?--irv
    [joyce & irvin toms]
    Very Active Member robmorg's Avatar
    Oct 2013
    Pottstown, PA
    Love my F4 Customs stock height windshield with the Honda vent. It's a bit thicker than the OEM, crystal clear, and scratch resistant. And it covers up the bottom holes where dirt used to get in between the windshield and the bracket. You can also order it in other heights, widths, and tints.
    Rob
    2013 RT Limited
    My "Mods & Farkles" Link
    May ALL your roads be beautiful
    Greisemer's Mill Bridge, Oley, PA
    2013 RT Limited , Lava Bronze with Antler Brown Seat
    Very Active Member jnt's Avatar
    May 2008
    Minneapolis
    While the stock shield worked ok, I soon got the OEM vented one. Really cut the buffeting to near zero except in truck traffic. Also 5'10" with full helmet. Love it tho couple areas tricky to clean.
    08 RS/SM5 (Hers) (sold)
    15 RT-S (Mine)
    2015 RT-S , Metallic Black
    Oct 2014
    Ohio
    Quote Originally Posted by jnt View Post
    Thanks to everyone for all the responses!!!!! Apparently the vent makes a huge difference, I am going to give it a try... Thanks again to all, love this forum, lots of info........
    SpyderLovers Sponsor F4 Customs's Avatar
    Nov 2012
    Twinsburg, Ohio
    Default Windshields for the RT
    F4 Customs offers a variety of shields for the RT. All of the shields are made of Poly-carbonate and not Acrylic and have the High Scratch Resistance Coating built in.
    They Shed Rain, are Optically Perfect, and Clean with paper towels and any glass cleaner you want to use.
    You can purchase them with a 5 position adjustable vent or without however we suggest the vent as this cuts down on the back pressure and gives the rider air when required
    All shields come in Clear or Tint and have a 4 year warranty.
    We sell a 22", 25" (which is stock height) and a 28". All can be purchased 5" wider than stock which is great for moving the air out and around the rider and co rider.
    We would love to earn your business.
    Give us a call or check us out at www.f4customs.com
    Don Frank
    F4 Customs, Inc.
    "The Motorcycle Windshield Folks"
    941-347-7496
    sales@f4customs.com
    <a href='http://www.spyderlovers.com/adserver/www/delivery/ck.php?zoneid=22' target='_blank'><img src='http://www.spyderlovers.com/adserver/www/delivery/avw.php?zoneid=22&cb=567846784' border='0' alt='' /></a>
    Oct 2014
    Ohio
    Default F4 customs
    Don,
    thanks for the post....
    yesterday morning I sent you an email asking for info and your opinion. You replied, gave me your phone number.. I will try to call you this morning sometime....
    Active Member STELLING MAN's Avatar
    Oct 2014
    Southern Ohio
    Default F-4
    I put a F-4 tall and wide with a vent on my RT-S about 6 mo. ago and I love It, It Is everything Don says It Is..
    2013 Viper Red RT S-SE5 All 48 states on a Gold Wing now I'm working on getting all on a
    Oct 2014
    Ohio
    Default Ordered
    On Thursday morning I called F4 to order the windshield. Talked with Don's daughter, Alicia. She said she would get the order out in the afternoon, on Friday Fed Ex delivered the windshield. One day service ........ Great service, really nice people to deal with, much appreciated!!!!!!! Will do the install this morning and have a test ride....
    Now, we're just waiting to hear some good news about it, from you!
    Oct 2014
    Ohio
    Default F4 windshield
    Rode 279 miles for a day ride with the new F4 windshield. It performed as Don Frank at F4 Customs said it would !!!! The wind noise is greatly reduced and most important for me, the side buffeting is gone... Perfectly clear vision. It worked as advertised, I am a happy customer !!!!!!! My wife riding as a passenger likes it also, so all is good ...........
