Results 1 to 6 of 6
    Active Member WisconsinDavid's Avatar
    Sep 2018
    Beaver Dam WI
    Default 2010 RS adding BajaRon Sway
    Just ordered the upgraded sway bar from Ron. Will be installing it after Easter. Anyone who has done this installation on a pre-2013 RS, any advice for the install? I see that I can do this without removing the frunk (or removing it). Anyone done this without removal of the frunk? Any tips? Thanks in advance, everyone. And.. thanks Ron for your great products/service!!
    Default You can...
    You can do the installation without removing the frunk but it is much easier to do without the frunk in place. Some will remove the bottom bolts and prop the frunk a little out of the way. I removed it to allow access to the zerk (grease) fittings and do a lube job as well. I do have some pictures in my albums but not much to go on.
    Gene and Ilana De Laney
    Mt. Helix, California
    ​2012 RS sm5
    Very Active Member JerryB's Avatar
    May 2014
    Beaverton, Oregon
    Hi David,
    Re: Any tips?
    Here you go:
    Frunk Removal:
    https://www.youtube.com/watch?featur...&v=p_JXqJhZCw0
    Sway Bar Install:
    https://www.youtube.com/watch?v=li0_Is7K3MM
    Jerry Baumchen
    PS) Some have done it w/o removing the frunk; but it is much easier if you do remove it.
    'I'll never forget what's her name.'
    'Things are more like they are now than they ever have been before.' Dwight Eisenhower
    2008 GS SE-5
    Johnson, Vermont
    I removed the frunk. It's easy to do and makes the job a lot easier.
    Aug 2019
    Milwaukee
    Hi Jerry,
    Thank you for your Bajaron anti-sway bar installation videos. I noticed that you did not install new metal Heim Joint Links. I have a 2008 GS990 SM5 Spyder. Are there Heim Joints on this model?
    Thanks,
    Tom
    Quote Originally Posted by TomRobinson View Post
    Hi Jerry,
    Thanks,
    Tom
    Hello Tom,
    Just letting you know that I answered this question to your post in this thread.
    https://www.spyderlovers.com/forums/...jaron-sway-bar
