Results 1 to 25 of 32
    Ft Pierce/Lk Placid
    Default If/When Ryker Chip Key Mechanically Fatigues
    At some point, the action of putting on & taking off the chip key from its mount will fatigue the plastic, and when you're going down the road, one of the tabs will break off, and your key will go flying off! Anyone give thought to this potential scenario?
    You could probably make a lanyard with a zip tie, going thru two of the tabs.
    Very Active Member Tslepebull's Avatar
    Dec 2018
    East Texas
    I really only take mine off when I am shopping or something. I can see it in the parking lot at work and it is in a locked garage at home. Besides, if I took the key off at work all my cohorts couldn't have so much fun riding it around the parking lot.
    2019 Ryler Rally , Shock Yellow
    Bossier LoUiSiAna
    Sales person tried to sell me it could stay in your pocket & didn't need to clip on every time. Like I said "tried" , seems feasible I guess, & not for me.
    Johnson, Vermont
    Been using one of these "fobs" on the snowmobile for 4 years. No problems yet with breakage.
    Dec 2018
    Missouri
    Quote Originally Posted by Rob Rodriguez View Post
    4 years sounds good enough for me. I'll do 4 and then switch and do 4 with the other key (two came with mine). By the end of 8 years I'll be ready to trade. Then again might not get to 8 before a trade. I wouldn't worry about it.
    Dec 2018
    NY
    I tried riding without the key. Got a message to check key in the bottom display which replaced the tachometer reading. It would also replace the miles to empty reading or anything else set to display there. Bike ran fine with the key removed after starting.
    Current: 2022 CAN AM F3S SS. Manta Green, Route 129 windscreen.
    Previous:CAN AM Ryker Rally. Intense black, side case , comfort drivers seat, comfort passenger seat with back r test, wind screen, LED auxiliary lighting.
    2022 F3S, special series , Manta Green
    Ft Pierce/Lk Placid
    Quote Originally Posted by Jsmith8695 View Post
    At least you can get home, if the unlikely happens.
    Very Active Member Markubis's Avatar
    Jan 2018
    NH
    I thought key fob could be pulled off and put away once the bike is started. Isn't that the case?
    Ft Pierce/Lk Placid
    Quote Originally Posted by Markubis View Post
    I'll try it!
    May 2009
    Connecticut
    My Sea Doo has the four sided FOB and one broke off and it still held on fine ever since. Of course I have the spare fob on board.
    Sea Doo GTI-SE 90 Jet Ski!!
    Ft Pierce/Lk Placid
    Quote Originally Posted by Aufgeblassen47 View Post
    I'll try it!
    Maybe I'll just add a lanyard. After all, the chances of your key falling out of your pocket after starting it may be greater than it falling off!
    Active Member mikeyuberalles's Avatar
    Feb 2019
    Clearwater, FL
    If you remove the key after the tryke is started, you get an annoying message about the key missing at the bottom of the display.
    Florida Swamp
    I am not sure exactly why a key would break, but it is a very simple thing to just sew a small leather cover on the top part of the key with a lanyard or something attached to it.
    2019 F3-S , Black & Silver
    Mar 2019
    Ruidoso Downs, New Mexico
    Too bad we can't just drill a small hole in the thing and fit a proper key ring! I don't suppose the chip would like that though!
    Feb 2019
    Clearwater, FL
    Quote Originally Posted by McRuss View Post
    Somebody on one of the numerous ryker facebook groups did that. As I recall, they popped the fob open to find a safe spot to drill and did it.
    Florida Swamp
    Quote Originally Posted by mikeyuberalles View Post
    There is a U-Tube video of drilling a Can Am key and it still worked. What I would be concerned about is just how water-proof the components inside the key are after the hole is drilled in it.
    Ft Pierce/Lk Placid
    Quote Originally Posted by Gwolf View Post
    It doesn't seem waterproof already, as the white covers are loose & not firmly sealed.
    Mar 2019
    I'll have to find that video. I only want a 'key' ring so that I can attach it to a zipper or something when I take it out/off. And I don't think water would really affect the chip anyway, just let it dry out. OK, the video is of a Spyder key and they are somewhat different (much like my Vespa chip key). I suspect drilling very near the edge would be OK, will probably try it!
    Florida Swamp
    Ft Pierce/Lk Placid
    Link please!
    Ft Pierce/Lk Placid
    I figured out the link, but there is nothing that would keep the Ryker key from simply falling out. A regular key with a hole/key ring provision would do it, but we have none.
    http://thecarry.com/small-goods/hobo...y-head-covers/
    Dec 2018
    East Texas
    Your dealer can reprogram the DESS key to work with your Ryker. Just buy one of these and take to the dealer for reprogramming.
    https://www.amazon.com/SKI-DOO-DESS-...%2C194&sr=8-24
    Mar 2019
    IIRC, the Ryker comes with two 'keys.' I intend to drill a hole in one of them; if it renders it unusable, I'll just get another, maybe for a Ski-Doo.
    Ft Pierce/Lk Placid
    How would a Ski Doo key be compatible with a Ryker? A chip is far from the old fashioned purely mechanical lanyard of PWCs of the old days.
    Johnson, Vermont
    The Ski-Doo's have the same fob as the Ryker (not sure about the Sea-Doo's?) I'm told you can program one fob to operate all your BRP products. Then you just need one "fun" key to control everything.
