Results 1 to 7 of 7
    Member Luna's Avatar
    Aug 2018
    Las Cruces, NM
    Default OEM Adjustable Air Deflectors Installation
    Hi folks!
    I'm finally getting around to installing my adj. air deflectors (after 6 months!) but am having a bit of an issue. You would think it would be simple - just take the stock ones off and screw in the new ones. Well even though I used the screws that came with the new deflectors (same length as the original ones, btw), they are a bit loose and wobbly. Were there supposed to be some rubber washers to go between the deflector and the body panel? There were none in the box but it seems like that would solve the problem. Or maybe the box contained the wrong screws? Anyone else have problems with these?
    Laura Moon
    French kissing life square in the mouth....
    LDYBLU - 2018 RTLE
    Bryant, Arkansas
    Try using the original screws, they should not be loose or wobbly, you may have to get the proper size screws if you were given the wrong size.
    Cruzr Joe
    Nov 2015
    Chardon, OH
    If memory serves, the new screws come with a fresh coat of thread locker on them. It may make them turn harder but they're really not fully tightened yet. If you are certain they were the same length, turn on them harder or, as Joe said, use the old screws. Or first, screw them in all by themselves without the deflector and see if they actually screw in the whole way.
    Doug
    ”Freedom is not a loophole”
    Aug 2018
    Las Cruces, NM
    Cruzr Joe
    I tried the original screws as well - still loose.
    Laura Moon
    LDYBLU - 2018 RTLE
    Nov 2015
    Chardon, OH
    Rather than a washer between the deflector and body panel, try under the screw head. See if that gives you the extra that you need. The deflector should cinch up tight to the body.
    Doug
    Jun 2010
    Las Vegas
    They should not tequire a washer. Be sure you have your screwdriver at the proper angle when tightening
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Very Active Member OverHillAndDale's Avatar
    Sep 2014
    United States
    I have those air deflectors, and I have nothing between the screws and the deflectors. Mine are plenty tight.
    2020- RT Limited
    Chalk White, Can-Am rear passenger armrests, Comfort Seat, Grip puppies, RAM Cup Holders, Providence RAM Mount
    FOBO2 TPMS
    Aluma MCTXL trailer
    BRP hitch
    Big Bike Parts wiring harness
    Permanent Smile!!!
