Results 1 to 4 of 4
    Ohio
    Default Buying a used Spyder
    When purchasing a used Spyder, or any vehicle, you are somewhat dependent on the seller to provide accurate information on the bike such as maintenance and/or problem history. Given the electronic monitoring capability of the Spyder is it possible for a dealer to "plug into" this system and provide the buyer with an accurate history of the bike?
    Poasttown
    Quote Originally Posted by Poasttown View Post
    Poasttown
    Actually it gets better …. all you really need is the VIN & a helpful dealer …… But most spyders that are owner maintained won't have that info in the BRP record system...……...good luck …… Mike
    Ohio
    Thanks Mike
    Very Active Member robhowen's Avatar
    Apr 2015
    Tucson, AZ USA
    The dealer can plug-in and tell you a bit about the owner's riding style, rpm, shifting, etc. Mike is right if the seller self-maintained, but if the seller purchased oil, filters, etc from the dealer and/or has good records, you can get some sense of maintenance.
    Good luck.
    Rob
    2015 RT-Ltd SE6 and F3S SE6, both with a number of commercial add-ons plus my own tweaks.
