Results 1 to 14 of 14
    Apr 2013
    Republic of Ireland
    Default 2019 Spyder RT LTD - Battery dead - check DPS warming and multiple fault codes
    Hi,
    Recently purchased a new 2019 RT Ltd and trailered it home. Left it in garage for two days and it wouldn’t start, completely dead. Put it on battery tender for 24 hours and started no problem. Went for a ride of approx 80km and when indicating to turn left off motorway got a fault code B100F also got two other codes but I can’t remember them. Rode home and turned off RT and turned it on again fault code disappeared. Then tried to use indicator again to see if that was the problem and immediately fault code B100F appeared again. The indicators both in the dash and on the bike were hyper flashing. Left the Spyder overnight and didn’t plug in the battery tender and went to the garage turned on the RT and while stationery in the garage played around with BRP Connect to try and get Genius maps audio to play through my helmet. Suddenly it throws up multiple fault codes, the screen starts flickering and I get a “check DPS “ warning. I switched off the Spyder walked away and came back and switched it on again and it seems like it could barely light up the dash so I turned it off again.
    My apologies for the long description but I just wondered if anyone else had experienced the same thing on a brand new Spyder RT.
    The fault codes shown were as follows.
    U0259
    U0122
    P1F09
    P0562
    P062C
    C006C
    C1290
    U0131
    U0123
    U0126
    Mar 2013
    ST Bonifacius, MN
    Have not had this issue, and I am sorry to hear you are. This sounds like a bad battery issue as that can cause multaple codes.
    The dealer needs to fix this!
    2015 F3S, 2018 F3L
    but our benefits don't?
    Active Member robhowen's Avatar
    Apr 2015
    Tucson, AZ USA
    What a horrible initial experience with your '19 RTL. I wish I could help you. I strongly suggest you take this back to the dealer and make it their issue as what if there are other issues with your new bike.
    The best to you,
    Rob
    2015 RT-Ltd SE6 and F3S SE6, both with a number of commercial add-ons plus my own tweaks.
    Apr 2017
    North Central Florida
    Quote Originally Posted by Silversurfer1 View Post
    Yes. Dealers are not good at keeping the batteries charged while they sit on the showroom floor.
    And letting them sit there dead makes them go bad.
    It is possible that there is a loose connection OR that the charging system is not working.
    But regardless of what the problem IS it should be fix under warranty, including towing to the shop.
    DO NOT LET THE DEALER TRY AND TELL YOU THAT JUST CHARGING THE BATTERY WILL FIX THE PROBLEM.
    THAT ISN'T GOOD ENOUGH.
    My ride: '17 Spyder RT
    Default Little checking.....
    After looking up all the codes listed they all relate to the electrical power loss. Most are lost communication. Do need a battery check... charge, condition and connection. On the charge do it with a charger not a tender. Might check the charging system, as one code mentions this, output as well. Only do this if getting it to the dealer is an issue and this is on them....
    ​2012 RS sm5
    Apr 2013
    Republic of Ireland
    Thank you so much everyone for the help. It was a brand new out of the crate Spyder so I am bringing it back to the dealer ASAP to fix. He thinks it’s the battery or bad connections but that’s only diagnosing it over the phone. Either way it will have to go back.
    Jul 2010
    Las Vegas, NV
    If you have a multimeter, get the bike running, check if the battery is charging. As Gene mentioned, check connections. Might be as simple as a loose screw. They throw all kinds of codes if the voltage is not just so. Insist on a new battery anyway. Good luck, and post what’s happened. Cheers! Joe
    Joe Meyer
    Apr 2013
    Republic of Ireland
    Cotjam thanks for your suggestion. Since it wouldn’t start after the two days in the garage I hooked it up to Optimate 4 Dual Program Battery Charger / Maintainer for a few days. It showed red for the battery initially (dead battery) and then green. Then after riding it for approx 100 km and playing around with BRP Connect while it was in the garage it threw up all the codes. I put it back on the tender yesterday and it showed red on the charger again.
    GOS member (Girls On Spyders) Spyder_Cowgirl's Avatar
    Bowie, Texas
    If your charger / tender is showing red that quickly, it really sounds like you need a new battery. And, as above, the dealer needs to make this right … including, if necessary, getting it towed to their location. Since it is not clear, from above, if the charging system is working properly …. I would hesitate to ride any distance (make them come get the Spyder AND bring it back to you when it's fixed). IMO, they either sent you home with a bad charging system, a bad battery, or both.
    So sorry you are facing these problems on a brand new machine -- once you get it all sorted out, I am sure you will love the ride.
    All the best …. Ann
    __________________________________________________ _
    2016 RT Limited -- "Jubilee" (as in Cherries)
    Guardian Bell (gift from spyderowboy)
    ISCI Dual Flag Mount – Tall Poles
    Lamonster Bottle Holder and Spyder Cuff
    Spyderpops Missing Belt Guard
    Spyderpops Bumpskid
    Spyderpops Rear Run / Brake / Turn LEDs
    Spyderpops Mirror LEDs
    Custom Dynamics HMT Brake
    Spyderpops Keep Out The Trash (KOTT) Grills
    Don't Eat Mud / mudflap
    __________________________________________________ __
    Apr 2013
    Republic of Ireland
    Thanks Ann for your helpful comments. I absolutely love my new RT but I’m bitterly disappointed that I now cannot ride it until this issue is sorted. I’m hoping it won’t take long to fix it.
    Active Member AAbruzzese's Avatar
    Apr 2019
    San Tan Valley, Arizona
    Hi I had the exact same thing, I headed over to autozone and bought a 60$ battery booster power unit and charged the bike for 10 minutes and it fired up no issues. I also called them and told them, they said if it happens again and you are still in your first 30 days being it in and they will replace the battery.
    Active Member BRPcare's Avatar
    Jun 2013
    Québec, Canada
    Hi,
    U0259
    U0122
    P1F09
    P0562
    P062C
    C006C
    C1290
    U0131
    U0123
    U0126
    Hey Silversurfer1.
    We are very sorry to hear that you have been experiencing these concerns with your new Spyder.
    Your dealer would be the best placed person to assist you with your specific questions as they are technically trained and have direct access to our technical support team, our warranty department and various other departments that could be of assistance.
    We invite you to reach out to them and they will be happy to assist you.
    Please do not hesitate to reach out to us by email at brp.care@brp.com or you can call us directly at 1-888-272-9222 if you have any other questions or concerns. Please be sure to provide us with your unit's VIN and we will be happy to see what we can do for you at that time.
    Kindest Regards,
    David-BRPcare
    BRPcare
    Social Consumer Experience Team
    Apr 2013
    Republic of Ireland
    David, thank you for your post. Hopefully the dealer will be able to sort my problems. I’m waiting for him to come back to me.
    Apr 2013
    Republic of Ireland
    Having put the RT on the charger/tender for the last couple of days I tried starting it again. It started straight up and when I went to check active fault codes I got the following;
    U3001
    P0504
    P062C
    P0556
    I’m just so gutted that I can only look at my new RT in the garage and can’t ride it. To have paid so much money on a machine that is faulty out of the crate is unbelievable.
    I really love this machine but I am so disappointed and angry right now.
