Results 1 to 25 of 31
    Active Member Boilermaker's Avatar
    Sep 2015
    Muncie, Indiana
    Default RTL MPG Question
    I have a 2018 RTL (10th Anniversary edition). Went out for a 50 mile jaunt yesterday through countryside and on highway. Clicked over to mpg screen to see how it was doing. Through the countryside I was getting around 36 mpg, which I expected. But, when I went out on the interstate running at 70-75 mph, the mpg went down to 25 mpg and stayed there pretty consistently. Granted, I was running into a headwind for most of the way. Ran about 15 miles at that speed, but did notice the fuel gage starting to drop. Just wondering if anyone else sees this type of reading on their RT? I know the only real way to check mileage is from tank-to-tank after refueling, but I thought this was an interesting observation. Thoughts?
    INDIANA, USA
    Default Mpg
    Seems about right with the list of conditions that you posted. The faster the Spyder goes the more she burns the fuel. I usually get around that range (36 - 25 mpg) too. ENJOY your RYDE and Always RYDE SAFE....
    ENJOY YOUR LIFE WITH A SPYDER
    Apr 2017
    North Central Florida
    Quote Originally Posted by Little Blue View Post
    Which is true of any vehicle with any engine.
    Seems about right to me too based on manual calculations with my '17 RT.
    Sep 2015
    Muncie, Indiana
    Glad to see mine is not out of the norm, but it seems that when I have done longer road trips in the past, I can get around 180 miles before the fuel light comes on and 200+ before I need to fill up. If I am only getting 25 mpg, I would have thought that I would be in trouble at 150 miles. When I think back, I probably just haven't run at 70+ mph for long periods of time. Thanks for the feedback!
    indpls in
    the wind really has an effect on fuel mileage
    Sep 2016
    Chillicothe, Oh.
    Spyders are as aerodynamic as a barn door. My RT gets in the 32 to 36 MPG range most of the time, but at speeds above 70 the mileage does suffer. We rode yesterday and had a pretty strong wind with some gusts above 30 MPH and that did zap the mileage very quickly.
    2015 RT , Black
    Active Member Zoot's Avatar
    Mar 2019
    AZ
    MANY years ago I used to ride a Suzuki 2-stroke street bike. 250cc twin, expansion chambers... I rode it around the small town where I lived, to work, etc. and was averaging about 30 mpg. I finally got a chance to take it out on the highway for a longer ride (~75 miles at 65 mph) and mileage dropped to about 15 mpg!
    Sep 2015
    Muncie, Indiana
    For those of you who run an RT 1330 for long distances on interstates, what is your normal range between fill-ups? Does pulling a cargo trailer make much difference?
    Very Active Member AeroPilot's Avatar
    Nov 2012
    Pueblo Colorado
    Depends whether you drive the interstates at 80 or backroads at 60 mph
    At 60 mph with regular open road and no headwind expect 40 MPG plus. Chasing the semis down the interstate at 75-80 you will get less than 35 Miles per gallon.
    Ann can probably give an idea on the affect of towing a trailer. The biggest difference is how fast you run and the wind direction. Add the wind speed to your ground speed depending on direction. If you like to run the interstates, plan on fueling up every 150 miles with your RT...
    07 Shadows, Aero, Spirit gone but not forgotten
    03 Harley Sportster, 07 RK moved on
    11 RT- 76,000 mi, 15 RT-S- 44,000 mi, traded for current 15 base RT and 16 F3T
    2015 RT , OEM Black Gloss
    On my 14/1330 I get consistent high 30's. I don't use a mpg gauge, but check mine on a per tank basis. Never any towing or two up riding.
    I will also add...I ride no more than five above the posted limit.
    I'm kind of anal about tracking the mileage numbers that involve my Spyder and have detailed them elsewhere on SL. I bought it for the fun of being out in the open air and not in a cage. My basic approach to riding is if I have to get somewhere in limited time, minutes, hours or days, I use interstates and accept the decreased mileage per tank. If not time constrained I use back roads and U.S. highways as I find they give the biggest fun reward. Life's too short not to have as much fun as you can, particularly when you spent your prime years on Uncle Dudley's short leash.
    Active Member FalconAF's Avatar
    Mar 2019
    North Las Vegas, NV, Third Rock From The Sun
    2018 RT Limited. 75+ MPH will definitely put you in the mid 20's MPG. I was coming back to Las Vegas from Laughlin, NV yesterday morning. Speed limit 75 so I put the cruise control on 80. Steady 24 - 25 MPG as long as it was there. With the new firmware version 20.8 showing the remaining miles available on the digital dashboard, it was showing about 120 miles remaining with about 3/4 gas tank indication. You're gonna suck gas like crazy at 75 MPH and above...even with a tail wind. Which is still a bit shocking to me, as my previous Honda NT700VA 2-wheel sport tourer got 45+ MPG on the interstate at 80 MPH. But...well...it only had a 700cc V-Twin. And it ran on regular unleaded too. So....
    2018 Spyder RT Limited
    May 2017
    Mesa, Arid-Zone-A
    FWIW..... I just got back from a 2 day trip with some friends. There were two 1800cc GW trikes and me. Both GWs were riding 2 up and I was solo. I was pulling my 622 trailer and riding in the middle. Neither of the GWs were pulling a trailer. We rode the same speed distance and roads for over 500 miles. At each fuel stop, I put in consistently a little over one gallon LESS than the two GWs..... Jim
    Semper Fi
    Mar 2019
    Quote Originally Posted by canamjhb View Post
    That sounds about right. Prior to my accident on my Honda V-Twin 700cc 3 years ago, I would do road trips with a friend who owned an 1800cc Wing. We would have to stop every 180 miles for him with his almost 7-gallon fuel tank. I'd still have between 1/4 and 1/2 fuel remaining. His Wing weighed about 950 lbs at 1800cc. Compared to our Spyder RTL's at 1330cc's and just over 1000 lbs (dry weight) with the same fuel capacity (6.9 gals), we should be getting slightly better mileage than an 1800 cc Wing.
    Jan 2019
    Blue Mounds Wi
    Does eco mode affect mileage?
    Quote Originally Posted by Boilermaker View Post
    Distance between fill ups depends mostly on distance to next gas station and bladder capacity, ususally 100 to 120 miles. And yes, pulling a trailer can hurt MPG if, especially if it is not small, really light, and aerodynamic. As others have said, speed can be a real killer as well as headwind. I've experienced MPG as low as 17.
    For some graphs of a couple of years of my MPG experience look at this thread: https://www.spyderlovers.com/forums/...t=fuel+mileage
    Sep 2015
    Muncie, Indiana
    Quote Originally Posted by JeffandLori View Post
    Theoretically, it should help overall gas mileage because you shift at lower RPMs, but once you are running down the road in a given gear, everything else is the same. Most don't use it because they shift by RPM or sound and the shift points in ECO mode are at relatively low RPMs. I don't think it makes enough difference compared to the pain of having to look for the little arrow telling me when to shift.
    Active Member ricford's Avatar
    Jun 2015
    Calhoun, La
    I don't really now about mileage but if 25MPG at 75 is normal, that's great to know. I ryde on long trips until the fuel light comes on. Don't know just how far I can push it but I have gotten 40 more miles after the light comes on. I have put 6.9 after that on a fill up so it was close. But, not to worry, I carry a 2 L spun aluminum fuel cell just in case I get carried away... I notice lots more folks are now going on rydes these days. I would ryde more often this month but this damnable daily rain in the South month prevents many long rydes. But, hang in there..... Before you know it, it will be just too darned hot to ryde... Which is worse, cold day rydes or hot day rydes... (ryding at night is the only way to travel in June through October) I hope everyone gets lots of miles in the next few months. Personally, when I start a ryde, I just don't want to stop and go home. I want to just keep going and you know, the rabbit thing....
    Apr 2017
    Forum won't allow just +1 as a reply so............
    What he said.
    Jan 2019
    Blue Mounds Wi
    I don't look for the arrow either. I do know with it off and I punch it the tire spins a little. With it on it doesn't. Very new here so I am still learning from the seat and forum.
    Mar 2019
    Las Vegas
    I am in the process of manually checking my fuel mileage now. New bike on my 3rd tank. I noticed that the electronic mileage calculator says I am averaging 70MPG. I know it’s wrong but it seems to be stuck there at 70 and doesn’t reset after a fill up (like my car) and there is no way that I can see to manually reset it.
    2018 RT Limited White/Chrome.
    BlueSeaSky front & rear dash cam.
    USB plugs
    TechMount cellphone holder
    Squared Away laser alignment.
    BajaRon anti-sway bar and links.
    Dynojet
    Ceramic coated cat delete pipe
    Jan 2015
    southern WI
    Interesting.....I've never really kept track, but I've never felt like my mileage ever "suffered".....just twist the "go grip" and enjoy the ride....fill up when the time comes
    2016 RTS , Pearl White
    Mar 2019
    Quote Originally Posted by VegasSpyder View Post
    See picture below. There are 2 "trip" tabs (A and B) you can use/view for individual trips. The 3rd "Total" tab is cumulative for the life of your Spyder. You cycle through the Tabs by pushing the thumb controller to the right.
    You can NOT reset the TOTAL mileage on the Spyder in the "Total" tab. But you can reset all OTHER items in all 3 tabs to "0.0" if you want. The secret is looking at the "down arrow 0.0" pointer on the right side...it is outlined in a RED border. That means HOLD DOWN (not just "push down") the thumb switch on the controller for a couple seconds until the values reset back to 0 on the display. This will not change the Total miles on the Spyder in the Total tab, but will reset the mileages shown in tabs A and B back to zero with everything else in those tabs (when you are in the A or B tabs). In the picture below, I just held the thumb switch on the controller down for a couple seconds. It reset everything in the Total tab EXCEPT the mileage AND the "total hours" (45h on my Spyder) back to zero.
    I reset tabs A and B as needed depending on how long my "trip" is. I reset both A and B to "zeros" at the start of any road trip. Then I only reset tab A at every gas stop, and leave tab B alone. That let's me use tab A to monitor individual legs for each gas fillup, but lets tab B maintain a cumulative trip display of mileage/fuel MPG for as long as I'm on the road trip (might be several days/weeks and hundreds/thousands of miles for tab B).
    I normally ignore the Total tab and use it just to see how many total miles are on the Spyder. This is the first time I reset it, just for the picture to show it can be done.
    Hope that helps
    PS - I have no idea why it displays "160 MPH" on the bottom. I've never had my Spyder up to 160 MPH. Honest. At least not in this lifetime.
    ...New bike on my 3rd tank...
    Curiosity about mileage is natural but I can assure you you're not going to see reliable mileage under whatever conditions you happen to be riding in until you've at least 3,000 miles on your Spyder. Your engine is in the infancy of its break-in process. Since you're in Vegas it would be worth your while to swing by a dealer and have them verify the system is working correctly and you are following the proper procedure to do the resetting. Better yet, give Joe Meyer of Squared Away a call; he can't be very far away and I'm certain he can help.
    Active Member bushrat's Avatar
    Apr 2017
    Peterborough, ON, Canada
    We're riding a 2017 F3L; same 1330 motor as RTL. We do two-up about 80% of the time, and have 12,000 miles on odometer. Spyder is pretty much stock. When riding back country roads doing sightseeing, averaging probably 55 mph, we routinely go 250 miles (400 km) before filling up, and have probably another 25 miles of fuel left before bone dry. Works out usually to be around 38/39 mpg; occasionally just over 40. Using 93 octane. Doesn't seem to change much whether we are two-up, or if I'm solo. We don't waste time, but don't do burnouts. I do keep revs in moderate range, and often downshift manually, usually well before the SE does on its own. However, if we throw in some Interstate or faster highway riding for part of the distance, the fuel consumption will drop to mid-thirties. Extended 75-80 mph travel will drop it more. If we pull our trailer (a very aerodynamic shape, light @ 200#), the consumption rate can drop to low thirties, especially if we also do higher speeds. My gas gauge has 9 bars that light up; I figure on getting 25 miles per bar fairly safely in average (slightly rolling countryside) ryding conditions. We really concentrate far more on enjoying our day, the scenery and the ryde, and don't get too much concerned about the amount of fuel burned. I monitor it out of curiosity; but whether up or down is not going to interfere with or stop us from climbing on the Spyder. Life is what it is, and costs what it takes.
    [SIGPIC]
    2017 F3 Ltd. Intense Red Pearl/Metallic Black topside
    2017 F3Limited , lowered brake pedal Intense Red Pearl w. Metallic Black topside
