Results 1 to 13 of 13
    Jan 2019
    Alliston Ontario
    Default Stebel Nautilus horn install 2008 Spyder RS
    Hi All.. This has probably been done- BUT I thought I would post my version of adding a Stebel Nautilus horn on my 2008 RS. I found the stock horn a bit wimpy and no one even bothers to look up from their darn cell phones! So I figured the Stebel may make them take notice.
    Very simple install just behind the power panel fuse box.. the sound horns point toward the Left "nostril" and the wheel well. Simple bracket using a 1" U bolt and a 5" steel strap from hardware store (the U bolt matched the holes in the bracket) Had to ream out the top hole for the Stebel mount bolt. Swapped the nuts on the U bolt to lock nuts. The U bolt fits the frame rail perfectly.
    Wired right back to the battery- Relay is where the old horn used to be.
    Its LOUD.. Hopefully will keep things a bit safer and heard! After this install I was advided the Stebel needs the compressor vertically mounted.. so I reworked the mount- same location same sound!
    Cheers
    Dave
    Feb 2019
    Portland, Oregon
    I'm wanting to do the same thing to mu F3L, but I can't locate where the OEM horn is located. If any F3L owner is lurking, would you please enlighten me? And is there a relay on the horn circuit?
    Default Congrats...
    Should work well there. The oem does sound wimpy at best.
    Gene and Ilana De Laney
    Mt. Helix, California
    ​2012 RS sm5
    Jan 2019
    Alliston Ontario
    It’s just one horn so no relay required as not a lot of load. Mine was located under left nostril panel. Toot the horn and listen and feel vibrations to locate it? A relay in needed for sure on the Stebel.
    Jan 2019
    Alliston Ontario
    Looks like the horn on the F3 is on right side under A arm need to take bottom cover off. Lots of Yourube vids showing where. Cheers
    Dec 2012
    Murphy, NC
    I have an F3-S and the factory horn is located on the right side. I installed a Bad Boy horn from Spyderpops and it went in on the left side. I connected to the same wiring as the factory horn. It was a pretty easy install.
    2020 F3 Ltd
    Spyderpops Bumpskid
    Active Member Zoot's Avatar
    Mar 2019
    AZ
    Love the Nautilus. I put one on my V-Strom a few years ago. Roughly a cross between a diesel locomotive and a semi truck.
    Just take my word for it... don't test fire it in the garage.
    Feb 2019
    Portland, Oregon
    I have one one the cage, plus one of the OEM trumpet horns. The dual tone is very penetrating and gets immediate attention.
    Very Active Member oldgoat's Avatar
    DDO, Montreal Island
    Quote Originally Posted by MoDZuKi View Post
    I installed my Stebel there as well on my '08 and I did use a relay.
    2008 GS SM5, Full Moon Silver
    2007 Piaggio MP3 - 250cc
    Active Member CA Railwhale's Avatar
    Aug 2016
    Sun City West, AZ
    It's probably the same place as a standard F3, right side, bottom of the bike near the forward peg. I had to buy the service manual to find it when I replaced my horn.
    Feb 2019
    Portland, Oregon
    A horn install will be the first electrical add-on and since there may be others, I will install a fuse block and run power to it from a relay. That way, everything I connect to the block will be relay + fuse protected and isolated from the bike's wiring.
    Jan 2019
    Alliston Ontario
    So an UPDATE! I was advised the Stebel needs to have the compressor mounted as vertical as possible!. Since I mounted it horizontal- I rejigged the mount and added a longer mount arm (fancy bending) so its now pointed down toward the wheel well in the same corner!basically rotated it 180 degrees and back 90.
    Feb 2019
    Portland, Oregon
    I ordered this 6 terminal fuse block from Banggood.com for 1/4 the price of a lower quality one that O'Reilly's had. It will mount under the right side fuse box in the frunk area. I'll wire it per post #11. More after the fuse block arrives.
    https://www.banggood.com/DC12V24V32V...r_warehouse=CN
Tags for this Thread
