Has anyone put the new style LED's in an RSS - I have to replace one of the halogen ones and wanted to upgrade unless there isn't enough room under the gage
thanks
ted
Have not done a extensive search but so far I have not found a kit or set for the GS,RS,RSS models. If you find one let us know....
I fitted leds to the lower lights ln a 08 gs today.they are hb3 in Australia. Any hb3 will fit.i use jw speaker here in aus.dont be tempted to buy cheapies
Got LED's in high/low, fog and running lights, got them from a company I used to work for CarId. Love them direct fit 20161124_165343.jpg20161124_165343.jpg
Improvise, Adapt, Overcome, Semper Fi
2020 RT
Limited heated seats
removable back rest & rack
XK Glow light
Paint with light painted panels
(Gone but not forgotten ) 2009 RS SE5
I just fitted LED's to my 2008 RS TODAY I'll post a tutorial on how to do it! Theres some tricky things about the rertainers that need to be addressed!..
Cheers Dave
When I replaced mine with HID, I ended up pulling cougar head off.
Just not enough room in there... I bent the flimsy metal holder on my first RS also when I did that one too.
Bulb size is h7 and I would think any h7 led replacement could fit but most vendors do have physical dimension listed.
Also, I think I’ve seen a vendor here have them.
I replaced my low beam and high beam globes with LEDs and then did the 4 eyes conversion so that when I switch from low to high beam the lows get turned back on. Well worth the money.
2014 RSS , 4 eyes conversion for headlights, 12v socket, 2x USB Ports, CTEK Charging Port. Black and White
Working on my 08 today, 2nd attempt at LED headlights. 1st one I bought a style of bulb that would not work with the power connector.
Now got Mercedes style clips but had a very hard time trying to put them in place. Might have to take the whole head off, space is too tight for my hands.
Foglights were easy to change, but got "limp home mode" after installation. It's weird how sensitive the computer is to LED lights. Had same problem with the tail lights but solved it today adding 2 sockets and keeping the halogen lighs tucked inside.
I personally would find it extremely helpful if those of you who find a direct fit LED replacement for the H7 headlight bulbs on our GS, RS, RSS models would please give the part # and supplier/link for them
I don't find it at all helpful when a post says: Amazon or Banggood has them as the choice is huge
Also, if you need to buy a pair of clips for them, I find stating 'Mercedes clips work' is not enough info. Exactly which model Mercedes would help as well as part #, supplier, link.
How do you get the dash up like that? I'm 100% new to motorcycles, bought the Spyder in December, will be registered this week, now that weather will get somewhat better.
Also, have you had any problems with Limp Mode after the LEDs installation?
In the middle picture there is that square bracket in the center. There are 2 10mm bolts that hold it down. They are not easy to get to, unless you have a swivel socket and lots of patience. you may have to trim the plastic piece right behind there to wiggle the console out. Once you get it it out, access is much much better.
So far I have not had any issues with limp mode.
My HID Xenon Kit arrives tomorrow, figured I need to pull the gauge cluster to do my bar risers, so I might as well get these done. I found a nicer set that are not returns for 114 dollars, and bought them, I think there are two more sets on FleaBay under 200. One of them looks like a return item, and I cant stand when people send stuff back after giving up on a project. Anyway, I hope it goes well, the stock H7's suck.
Kraig B. Kumlin, M.M., M.C.P. (Retired)
Only Two States Left to Visit on MC or Trike, RI and CT
2012 RS-S , Baja Ron Plug Wire Kit and NGK Iridium Plugs Grey and Black
